jibmaster1's Avatar
CHT and Reference sensor protective cover cracked question:
Have my engine/tranny separated for some oil leaks etc. I noticed that the protective outer layer on both the CHT an reference sensor crumbled off from years of heat cycling. Is that cover important, or just ignore it? Sensors all working prior to work... Thanks
Old 12-06-2013, 05:21 PM
Well, youre right there, fix it, better than trying to replace it in the car.
Bruce
Old 12-06-2013, 05:56 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Very important cover. Once moisture & crud get in there, you eventually run into intermittant no-start or poor driveability symptoms that are bothersome.
There's a BMW sensor that is the same exact sensor with just a bit longer wire lead. Much cheaper than the equivalent Porsche part. Do a search and save yourself some $. Replace them both.
They are both the same exact sensor, but perform different functions. One is for ignition timing (senses the flat "teeth" on the flywheel) other is for referencing the set screw in the flywheel & only needs to function when starter is cranking.
Kevin L
'86 Carrera "Larry"
Old 12-06-2013, 07:00 PM
French Import
zippy_gg's Avatar
I got the BMW sensors on Amazon for about $57 each: Bosch 0261210002 Engine Crankshaft Position Sensor.
I got the CHT sensor from our host.
I thought it would be best to replace all as I have the engine out and the protective layer was all cracked and just about gone like yours.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-06-2013, 10:20 PM
jibmaster1's Avatar
Thanks guys for your responses. Glad to see an option like using the BMW reference sensor. This 'while I'm in there' has been a slippery slope! But, nothing beats a sweet running, leak free 911! Can't wait to get her back together.
Old 12-07-2013, 09:19 AM
BUMMER!!! I just today replaced the crank speed and TDC sensors today, $158 a piece on Pelican... I could have saved $200 by buying BMW sensors!!!
Old 12-07-2013, 01:05 PM
1988 Carrera
shadowjack1's Avatar
Pelican part number is 12-14-1-708-618-M14. Position sensor for motornic igntion 325/e/es (thru 08/85)
Old 12-07-2013, 01:16 PM
Schleprock
KTL's Avatar
Tell them to hold your order & reorder the BMW sensor. I'm surprised Wayne hasn't adjusted the catalog for this known substitute
Old 12-07-2013, 02:49 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I think he is way past the order step…
But I agree and surprised that the BMW part does not shows in the "Other Brands Available" box.
Who Will Live... Will See
Old 12-07-2013, 03:37 PM
