Slippery Slope Expert
Steam Driver's Avatar
Front Oil Lines - Purging?
My SC sat for about 10 - 12 years before I acquired it as a "barnfind" (so to speak) I'm having to do a lot of work on it to get it back road-worthy and currently have the engine out (head studs). Here's the question: (Pardon me if this seems like a dumb one, but I've not seen it addressed anywhere.)
Should anything special be done regarding cleaning (blowing out, whatever) the oil lines and cooler before reinstalling and firing up the engine. I should note here that the oil I drained from the engine and inside the engine itself were clean as can be; no engine failure stuff or anything. Should I just leave the cooler and lines as they are, install the engine and run it?
Along the same line, what precautions should be used if the front to rear cooler lines and cooler are empty? Anyway to pre-fill them?
Old 12-12-2013, 04:45 AM
kodioneill's Avatar
If there's no contamination don't worry about it.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-12-2013, 06:03 AM
porsher
aston@ultrasw.c's Avatar
You don't need to prime the oil lines.
When the t stat opens oil will start to circulate all on its own.
You just need to check oil level when the engine is fully warmed up.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 12-12-2013, 06:53 AM
schumicat's Avatar
I would leave it alone, because there is a decent chance the treads will be ruined if you try to remove the oil lines.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 12-12-2013, 07:13 AM
French Import
zippy_gg's Avatar
I would replace the soft lines on the front cooler side as they tend to leak over time and are cheap.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-12-2013, 08:30 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Agree. Leave it alone.
I did replace a leaking line on the engine side of the thermo. Several days of Kroil and low heat with an odd looking setup of wrenches/blocks with an open torsion bar cover hole. Threads are very fragile and you don't have a good angle of attack for the front lines.
1981 911SC Targa
Old 12-12-2013, 11:21 AM
