-   -   Tool - window lifter (http://forums.pelicanparts.com/porsche-911-technical-forum/785989-tool-window-lifter.html)
glennspiegler 12-08-2013 06:38 AM
Does anyone know what and when this tool is used for? Came with my 88 911 Cab. Thanks, just curious. Glenn
#911 721 237 00. It is listed by our host.[img]
http://forums.pelicanparts.com/uploa...1386513283.jpg
GeorgeK 12-08-2013 06:46 AM
When the door window motor doesn't work, you remove the tweeter from the door panel, poke the vapor barrier, and there is the motor's axle, with a hex hole in it. You must have a crank in your toolkit to turn the motor to close/open the window. That is, unless someone changed the window motor for an older version that had no hex hole in its shaft (don'task me how I know...).
glennspiegler 12-08-2013 08:21 AM
Thanks George:
Now I know what the winder tool is for. Have had them both in the tool kit for 20 yrs. Thanks, Glenn
