gjs
glennspiegler's Avatar
Tool - window lifter
Does anyone know what and when this tool is used for? Came with my 88 911 Cab. Thanks, just curious. Glenn
#911 721 237 00. It is listed by our host.[img]
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff
2015 Cayman S
1948 Willy's Overland Jeepster
2013 Chev Sub
2004 Nisson Xterra
Old 12-08-2013, 06:38 AM
When the door window motor doesn't work, you remove the tweeter from the door panel, poke the vapor barrier, and there is the motor's axle, with a hex hole in it. You must have a crank in your toolkit to turn the motor to close/open the window. That is, unless someone changed the window motor for an older version that had no hex hole in its shaft (don'task me how I know...).
Old 12-08-2013, 06:46 AM
gjs
Thanks George:
Now I know what the winder tool is for. Have had them both in the tool kit for 20 yrs. Thanks, Glenn
2015 Cayman S
2013 Chev Sub
2004 Nisson Xterra
Old 12-08-2013, 08:21 AM
