new air filters
I've fitted my new air filters at last - any thoughts, probelems, how much will this affect mixture etc?
Steve in South Africa
If it isn't sideways, it isn't fun
Old 08-23-2002, 11:50 AM
Since fitting my filters yesterday, I've noticed popping and banging through the carbs - why?
Old 08-24-2002, 10:59 AM
tobluforu's Avatar
Not sure what you had before-stock? but, I would think with those that your running much leaner.
Old 08-24-2002, 06:06 PM
Stay away from my Member
campbellcj's Avatar
You may need to fiddle with the mixture, but also keep in mind that if you go to an exposed foam or gauze filter setup from a factory metal airbox, you will be hearing a lot more of whatever was going on there before. The big enclosed plenum of the stock airboxes really attenuate the noise of the induction quite a bit.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 08-24-2002, 08:21 PM
Send a message via AIM to Oldporsche
Cool
Popping noises? I believe that those are noises of the valves working in the airstream. The type of aircleaners you have installed will let you hear noises you've never heard before. The music will grow on you.
Good luck,
David Duffield
Old 08-24-2002, 08:45 PM
Yep, its music alright and I did have a stock system before (she's a 2.2T). I fitted two very short straight thru silences a few weeks ago so I suspect it is running rather lean.
Next step is a dyno set-up.
Thanks guys!
Old 08-25-2002, 09:57 AM
Steve,
Try backing out each idle mixture screw 1/8 turn and see if it makes any difference. If the filters created a lean condition, this will richen it up a bit and reduce the spit-back. Proceed with further tuning based on what happens next.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 08-25-2002, 11:01 AM
