Help, Looking for tires
I have a 79-930 with rims J9-16 rears and J7-16 fronts I need help looking for tires
285 or 275 40 or 45 16 for the rear and 245 or 235 40 or 45 16 for the front. If you know if they are available please let me know. Chowfun Hawaii
Old 12-09-2013, 10:41 PM
Banned
I've used this company several times and have been pleased with their prices and service -
Onlinetires.com - TIRES Search Results
Old 12-09-2013, 11:22 PM
Now accepting US $ at par
dienstuhr's Avatar
On 7" and 9" wheels you'd be looking for 225 for the front and 245 or 255-section for the rear. The sizes you've cited are all too wide.
Regards,
d.
1985 911 Carrera Coupe
2015 Volkswagen GTI 6-spd
some motorcycles
Old 12-10-2013, 08:08 AM
Hi dienstuhr, thanks for the your advise. Trying to go the widest to make the turbo look beefy. I did not want to use spacers to bring them to the edge of the fender well. Aloha
Old 12-10-2013, 08:32 AM
moneymanager's Avatar
Have you looked at TireRack? But those sizes are way wrong for your rims as pointed out.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 12-10-2013, 09:13 AM
Rescuer of old cars
Arne2's Avatar
The sizes you list are wider, yes. But they are also considerably taller, which is where the problem comes in.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 12-10-2013, 09:22 AM
dienstuhr's Avatar
You could consider going to a 10" wheel for the rear. That's the widest wheel that will fit stock Turbo bodywork.
Cheers
d.
some motorcycles
Old 12-10-2013, 10:53 AM
911 Besitzer
I've got 7's and 9's on my 84 Targa, and got Bridgestone Potenzas at Tire Rack, in the sizes Dienstuhr mentioned.
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 12-10-2013, 11:28 AM
wayner's Avatar
If you are using any other cars that you have seen as a reference point, make sure you know what their setup is.
On my 73 turbo flared wide body for instance I am running 275/40s on a custom built 17x10.5" rim with custom backspacing to get it to fill the flare without a spacer. It looks like a standard fuchs but it is not.
On the front I am running a 245/40 on a custom 17x9.
Once you find a tire you like, check out the manufacturers web site. They usually have a chart that shows min and max size rims for a given tire size.
SOLD - 914 wide body hot rod
Old 12-10-2013, 02:09 PM
