-   -   Where are the engine serial #'s located (http://forums.pelicanparts.com/porsche-911-technical-forum/78635-where-engine-serial-s-located.html)
Paul-V. 08-25-2002 03:24 PM
for a 1965 911? Is it that same number stamped on the rear fan (begins with 901) or is it stamped elsewhere on the case itself. Thanks.
pwd72s 08-25-2002 03:34 PM
Somebody correct me if I'm wrong, but I think it's in the same location on all 911 engines. There is a case upright post...go to 3:00 on your fan surround....look straight down, and you should see the upright post...moulded into the case, like a brace for the fan surround. THe number should be stamped there. If no number, it means a replacement case was used.
