NathanR's Avatar
Send a message via Yahoo to NathanR
Clutch squeaks when released
My 87 Carrera w/G50 transmission has developed a squeak when I release the clutch.
It started two weeks ago.
The car has 160k mi. The PO's mtce records indicate the clutch was replaced 40k mi ago. Don't know if that included everything or just the clutch itself.
The squeak seems to get better after driving the car 10-15 minutes (shorter duration, less pronounced). Our weather got a lot colder about that time, and I don't normally drive the car in the winter. On some shifts it doesn't squeak at all.
Other than the squeak, I've not noticed any operating problems.
Your thoughts?
R/
Nathan
87 Carrera Coupe
Black on Black, H4 Headlights, Nurburgring Sticker
Old 11-16-2013, 02:36 AM
Always Be Fixing Cars
Squeak from the tranny area or footwell area? Presuming former... Can you call the shop that did the clutch to see if the crossarm was addressed?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 11-16-2013, 07:01 AM
Check for loose alternator belt. I had that same problem and turned out to be old belt that needed replacement\
Old 11-16-2013, 07:12 AM
Reiver
Reiver's Avatar
Funny but true...for whatever reason many sounds seem to resonate thru the tranny.
Old 11-16-2013, 07:22 AM
NathanR's Avatar
r-mm -- squeak emanates from back end of the car. About contacting the PO's shop, the work was done in 2001, at Autowerks Northwest in Woodinville WA. The work order says, "Replace Clutch Assembly" and "Replace Flywheel".
For the sake of this post, let's assume the cross shaft was not updated. Could that cause the symptom I'm observing?
R & R, I replaced the belt last spring, and may have gotten the tension wrong (ie a tad too loose). Or maybe the belt stretched a tiny bit. Will check. The sound is like that of a belt slipping. Seems odd.
Thanks!
Nathan
87 Carrera Coupe
Old 11-17-2013, 01:21 AM
Since the cross arm problem involves bearings degrading i would think it could lead to a squeak. Can you have someone operate the clutch while you stick your head down there to do some forensic listening?
Is the problem exclusively on clutch disengagement (pedal pushed down) or reengagement (pedal released) or both?
Old 11-17-2013, 07:11 AM
NathanR's Avatar
So far, it only squeeks when I release the clutch. Maybe the sudden change in RPMs causes the alt belt to slip a little....
87 Carrera Coupe
Old 11-21-2013, 10:19 PM
its the alt belt. same thing was happening to me and i was stressing about the clutch. new alt belt and all is well
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 11-22-2013, 12:38 AM
theiceman's Avatar
.. did you just try it with the engine off ? if it is mechanical linkage/ bearing it should do it .. will eliminate the alt belt immediately if it does it with the engine off
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-22-2013, 05:07 AM
NathanR's Avatar
It was the fan belt...
Yesterday, despite all my blower motor frustration, had one bright spot. Was able to tighten up the fan belt, which solved this problem. One big step forward, two little steps back...
Thanks for your thoughts everyone!
N/
87 Carrera Coupe
Old 12-15-2013, 08:53 AM
