Red face New Clutch, PP and TO Bearing, No leaks and chatter, what gives?
Recently put a new clutch and PP as well as throw out on my 930 and put it back together and it chatters!!!! Ugggggghhhh!!! I still need to put the return spring on it, but what else is there to inspect. Any help is much appreciated. BTW, I also own an 80 SC and did the clutch on it, in the same fashion, and had no chatter. Help, Help, Help...
Signed,
Frustrated in Florida !!!!
Old 09-05-2001, 07:46 AM
Post
This sounds similar to what happened on a friends 88 930. He had the clutch cable replaced 3 times...it seems they were all the wrong length and the mech. finally got one that was correct.
Good Luck
Buck
88 Coupe
Old 09-05-2001, 08:08 AM
Post
more help please!!!!!! Thank you.
Old 09-05-2001, 09:38 AM
Senior Member
Superman's Avatar
Post
Well, of course, there's the tube thing that surrounds the clutch cable fron the tranny to the fire wall. This must be under pressure and consequently bent. I believe it also is secured to the tranny body by a grey strap. Also, worn motor mounts.
'83 SC
Old 09-05-2001, 10:04 AM
Post
Motor Mounts.
Old 09-05-2001, 12:16 PM
