-   -   How do I undo these? (http://forums.pelicanparts.com/porsche-911-technical-forum/787820-how-do-i-undo-these.html)
s1oww 12-18-2013 06:33 PM
I'm trying to remove the front dash panels. I can't get these undone.
I would assume they in screw, but I could be wrong or the previous owner glued them.
I also can't get the cover off around the ignition key?
http://img.photobucket.com/albums/v6...ps9hyp4c8q.jpg
group911@aol.co 12-18-2013 07:08 PM
All unscrew. On the black ones, I use two small screwdrivers that fit in the holes and a larger one to twist between the 2 to unscrew them.
The lighter unscrews from the back. Hold the front part and reach in through the clock hole to do it.
The ignition surround also unscrews.
s1oww 12-19-2013 01:52 PM
Thanks 😃.
The ignition one just won't move.
Festive_Zombie 12-19-2013 02:14 PM
The panel themselves are glues on and care should be taken when taking them off otherwise will rip... A sharpened putty knife works well.
pors1968 12-19-2013 06:19 PM
Take off wire and turn the swicth and it will loose goes by the clock hole like group 911 said .
