Howard (guest)
Guest
Posts: n/a
1976 911S speedometer wiring. Three terminals +, - and sensor. Do you know the color code? The ground is obvious and has two wires on the lug. The red wire has 12 volts on it when the ignition is turned on. Does the sensor lug have two wires on it?
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-21-2013, 02:41 PM
Nick at Pelican Parts's Avatar
Check this forum topic. It should be helpful:
- Nick
