3.2 engine dies when oil fill cap is removed
I've had this 1989 911 3.2 for 15 years it has 130,000 miles has always run well but when checking the oil the engine dies immediately after removing fill cap it has done this for as long as I have owned it. probably a vacuum line but could it be something else
Old 12-20-2013, 01:20 PM
Most likely the vacuum restrictor in the bigger breather line at the top of the oil tank is missing. It prevents a sudden drop so that the DME has a chance to regulate.
Old 12-20-2013, 01:31 PM
notmytarga's Avatar
You need:
930-107-289-00-M260 Restrictor for Oil Tank Breather Hose, 911 (1981-89)
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=930-107-289-00-M260&catalog_description=&Restrictor%2520for%2520Oil%2520Tank%2520Breather%2 520Hose%252C%2520%2539%2531%2531%2520%2528%2531%25 39%2538%2531%252D%2538%2539%2529%2520%2520
You will be able to check the oil level at idle!
I added one in my '75 to stop my tank from spilling into my airbox.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 12-20-2013, 01:32 PM
Thanks for the come back ill will check there first
Old 12-20-2013, 01:53 PM
Buy a $1.00 hose clamp set at hf ' to Check oil
Clamp breather hose check oil . 1 minute job
Old 12-20-2013, 06:37 PM
Project Addicted
Shows that you probably don't have any vacuum leaks or minimal at least :-)
I like the clamp option. Or a needle nose vice grip to pinch it.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 12-21-2013, 04:39 AM
