First engine drop - Mystery transmission
Fellow Pelican's I dropped my motor/tranny together yesterday on my 1971 911E. I thought the transmission would be difficult to separate from the motor but after I un-bolted it from the motor it separated very easily.
I thought the 71 tranny's where the "Pull" type? I did find "902/1" stamped on it. I also noticed the Oil tank had the two "nipples" on it consistent with the "Sportomatic" oil tanks. Could this tranny have been swapped? I've added a pic of the motors serial number if someone could help me identify it. ![]()
Yes, the transmission and other parts could have been swapped. I think the 902/1 was a 5 speed used during the SWB era, maybe around 1968. Your car should probably have had a 911/01. Yes, it used a pull-type clutch.
JR Last edited by javadog; 11-29-2013 at 07:30 AM.. |
Here are pics of the clutch and flywheel.
![]() ![]() NOTE the holes along the outside, is this stock or a modification done to lighten it? Vent it?
902/1 is a 911/912 with gear ratios AFMSX for MY years 65-67. The 902/01 is a four speed for a 68 912 with gear ratios AHQX
Bob |
Ok, Thanks guys. Further research shows any 911 or 914 6 bolt 215mm flywheel will work.
Anyone know anything about the motor's serial number? |
Fairly early production 71E targa motor.
JR |
Yes, 2.2 liters.
JR |
Under the radar
I have a '71 trans out of my E sitting in my basement. PM me if you are interested.
65-68 5 speed and clutch and flywheel. you will be better whith 70-71 trans diff is bigger and you get more clucth 225 .But clutch flywheel bearing are more expensive.
I am going to keep this tranny in my 911, I like the gearing and the shift pattern suits my driving style. Thanks everyone.
Guest
Posts: n/a
902/1 32 5 11:34 A 18:34 F 22:29 M 25:26 S 28:24 X 7:31 Simplified 220 001- 221 721 (to 26 Jul 65)234 001- 238 942 standard except USA/CDN, '65-'67 model years Diagram |
