Rockers sponsored by "Bondo"
Hi,
Below are some photos of what I found after cutting off the outer rockers on a '69 912/911 yesterday. It looks like that instead of using replacement inner and outer rocker panels, flat sheet metal was half heartedly shaped and welded in. The final profile was created with bondo. Whoever did the previous repair should be chastised for not doing it more "correctly" (realizing there are varying levels of correctness) but also praised for their obvious skill with bondo! I had a feeling it was going to be bad, but when my cutting wheel started spewing white dust (to be sure, A LOT of white dust!!) I didn't quite expect this! This tub will end up being one of those, "I can't believe he though it was worth it" rust repair jobs. And it likely won't be worth it in the end... except for the experience and to say that I did it. I am going to be needing A LOT of sheet metal on this one. I actually picked up another '69 912 roller/shell to use as a donor, but it is in such better shape, I hate to cut it up! The only place that has me concerned is the torsion tube. One bar is still stuck - I haven't been able to hammer it out yet from the other side. There are A LOT of rust flakes inside the tube and I worry that if I don't replace it, it might break at some point after the car is back on the road... not sure about that one yet. Tom ![]() ![]() ![]()
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
scary!... ultimate noise dampeners though. Rock on...
At some point, a larger chassis cut would be more economical and allow you to simply bypass all the rust. In cases like this, you can end up 'chasing' the rust into multiple panels.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
weekend wOrrier
That looks like something I'd do! -no- not really. I'm not even that bad!
I would rather be driving
My old ST started life like that when I got it. Glad I cut out the rockers and welded in new panels.
I usually switch to a body saw when I see that much dust.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Tom
Reiver
Man I know the feeling as you 'peel back the layers' oh no and wtf common comments. OTOH what should we expect from 40+/- year old cars that had no rust proofing to speak of.
Rennch on YouTube
I've got a spare inner rocker replacement panel taking up space in my garage if you want it. I think it's driver's side.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Thanks for the offer, I appreciate it! I will PM you. Tom
Senior Member
My '74 TR-6 had that, plus cardboard, in the sills. It was unreal to pick it apart. The body shop took pics and saved the tinworm'd sill and cardboard for their Wall of Horrors.
'78 Targa in Minerva Blue |
Fleabit peanut monkey
Dude was pretty wicked with the hammer too. Getting all that metal down in the right position so he could lay a precise 1/2 layer of mud on. Musta used layers.
![]() Guys at the car parts store say the "correct" method is to fill a void with that expanding foam. Not the cheap-o latex stuff. The real hydro-carbon based foam. The stuff that wont come loose. Shave it down, then skim coat to your taste with bondo. Silly, but I may try it on a beater someday for the heck of it.
1981 911SC Targa |
Bob, we've had cars come through here with foam in them. One of them was probably 20% foam. I guess it's not the worst way to go! At least there is structure behind your mud work that won't be shifting all over the place or lose its grip on the body. I knew a guy in the '90s who made some box rockers for his car out of (mostly) expanding foam. I never saw the finished product, but it was scary to see it in progress. - Matt
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA |
Kinda cool that for $6 you can apply your base structure.
1981 911SC Targa |
The biggest issue here is that the guy didn't use any chicken wire to help reinforce the bondo. What an amature.
83 Chrysler LeBaron 86 AMC Eagle 90 Geo Storm |
In my early days back in Australia, and during the time I worked in construction, I once cam across a work "ute" (an El Camino type vehicle for the uninitiated) that had had a 2" thick concrete floor poured over cardboard complete with reinforcing wire. You could still see the cardboard through the (large enough for a good size dog to escape through) rust holes if observed from below and the reinforcing wire (which was not quite submerged in places) would catch on the carefully relayed carpets. Had a strange effect on the feet and pedals but probably really improved the handling as a result of the considerable lowering of the centre of gravity.
Laurence 1998 Specbox racer / 1998 Boxster / 1984 RSR tribute 1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa 1963 356B T6 Coupe / 1962 356B T6 Cabriolet Current projects - 1955 356 pre-a Speedster / 1964 356C |
hell of a job ahead of you.. it qwill be worth it, not monetarily perhaps, but because they ain't making anymore and bringing one back from the dead is always worthy
I hope everyone has a great holiday and that Santa packs a few (RUST-FREE!!) early 911's in his sleigh!!!
We actually use quite a bit of 10# and 20# density expanding urethane foam in the sculpting and modeling phases. Also, when you compress the expansion, you can considerably increase the density and maintain sculptability. fun stuff
--toddc todd@helioncomposites.com www.helioncomposites.com |
Has anybody ever done that?
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Metro Detroit - just as many fenders flappin' in the breeze as in Akron (per capita). This is going to shoot right past getting turned into a "stickie". It's gonna be the first Pelican White Paper. White paper - Wikipedia, the free encyclopedia Somebody needs to PM Wayne.
1981 911SC Targa Last edited by Bob Kontak; 12-23-2013 at 02:30 PM.. |
