-   -   Fitting my IROC wing (http://forums.pelicanparts.com/porsche-911-technical-forum/788653-fitting-my-iroc-wing.html)
mreid 12-24-2013 02:48 PM
So right up front I will admit to liking things to fit properly. A friend of mine always says, "it's race ready". What he means is the fit is a 20 footer. That just doesn't work for me.
Today I started fitting my IROC wing. It's a well made piece, but has a few fitment challenges.
First off, notice the edges of the engine compartment opening are straight:
http://img.photobucket.com/albums/v6...ps572ac8dc.jpg
But not the wing, in fact it is too wide to fit in the opening about 1/3 of the way down:
http://img.photobucket.com/albums/v6...ps3009d45d.jpg
And there is a corner missing on the lower left side:
http://img.photobucket.com/albums/v6...ps73b78ef2.jpg
The actual problem is that the area under the straight edge need to be removed (where I've ground away the gel coat):
http://img.photobucket.com/albums/v6...ps1cc30468.jpg
http://img.photobucket.com/albums/v6...pscf4ce633.jpg
Cut up some strips of fg cloth and bond them in place:
http://img.photobucket.com/albums/v6...ps62a0d7ce.jpg
http://img.photobucket.com/albums/v6...ps494eac71.jpg
http://img.photobucket.com/albums/v6...ps5ec4502a.jpg
Also, need to fill in the edge, but I don't want the repair to snap off after paint, so drill a few small holes and bond in some pins followed by long strand fg filler:
http://img.photobucket.com/albums/v6...ps9sytjgun.jpg
http://img.photobucket.com/albums/v6...ps849f6900.jpg
Thursday I'll grind and fit it and then sand the entire wing and start filling pin holes and imperfections.
So many projects, so little time!
JeremyD 12-24-2013 02:56 PM
From another person with that same mindset - Thank You for making it fit correctly
Ayles 12-24-2013 03:08 PM
Why are fiberglass panels made with such lousy tolerances? Quite a few threads here with some heavy modifications done in order for them to fit right.
mreid 12-24-2013 03:08 PM
I knew you would understand, Jeremy!
