-   -   Power Window Switch Dilema (http://forums.pelicanparts.com/porsche-911-technical-forum/789104-power-window-switch-dilema.html)
jcgranato 12-27-2013 06:59 PM
Ok, I need some help! I had a rattle in the drivers door so I decided to tear the door apart. I have done this before with no problems,but this time something went wrong. As I took the five wires off each power window switch I labeled them in a clock wise fashion. I fixed the rattle, installed new vapor barrier and reassembled. I hooked the switches up, turned the key to test and nothing. Nothing except faint smoke from the window switch wires. I turned the key off, rechecked the wire orientation, turned the key and nothing. Except again smoke. What could I have done wrong?
Any insight would be great!
beren 12-28-2013 05:48 AM
Re-check the connections, but you probably fried the switch.
Bentley 570-2 says for an '84-89:
Left Window driver door switch:
1. blue
2. blue/black
3. single red/blue
4. brown
5. double red/blue
Right window driver door switch:
1. red/white
2. red/black
3. single red/blue
4. brown
5. double red/blue
jcgranato 12-28-2013 07:12 AM
Thanks, I will double check the connections.
86 911 Targa 12-28-2013 09:05 AM
Switch.
Pics from our '86:
http://forums.pelicanparts.com/uploa...1388250123.jpg
Driver's side-driver's window.
http://forums.pelicanparts.com/uploa...1388250150.jpg
Driver's side-Passenger window.
http://forums.pelicanparts.com/uploa...1388250176.jpg
Passenger side-passenger window.
Good luck,
Gerry
jcgranato 12-28-2013 11:49 AM
Wow! Extremely helpful. Thanks
