Installing roll pin into shift fork in a 915.
Attempted to install the shift rod fork roll pin and failed miserably. I damaged the pin as I removed it-anyone know the exact size? Also, what's the trick to installing the roll pin so it seats in all the way?? So close to getting her back together!
...and my blue mistress
I usually file down or mush it in the vise to get a little taper on one end. Start it with my thumb. Then whack away with an appropriate size drift.
I don't know the size of yours in question but just stick a few different size Allen keys in there until one is snug and I'd say you are there. I used to have trouble with these too until I picked up a set of drifts on impulse at harbor freight. All of mine had some kind of character to them courtesy of the grinder for whatever I was needing the tools for at the time. This went on for the past 35 years with the same drifts. The new ones all have clean flat tips and a variety of sizes. Never had a roll pin problem since.
Robbie 1976 Carrera3.0 1978 928 5spd |
Thread Tools | |
Rate This Thread | |
