autobonrun's Avatar
Question What changed in the 911SC?
For the first time I looked at the technical specification page here at Pelican. Two things are curious, 1) The torque increased from 203 ftlbs to 219 ftlbs from 1980 to 1981 and 2) the transmission shown for the 1979 is different than any other year SC.
With HP, transmission type, and compression ratios the same, how did Porsche get the additional 16 ftlbs of torque from 1980 to 1981? It appears maybe this is just a typo and the figures are off by a row and the compression ratio actually was changed from 1979 to 1980 which would explain the torque increase. Should it be 9.5:1 for 1980 through 1983?
What is the difference between the 915/61 and the 915/63 transmission? Why did Porsche change to the /63 in 1979 and more more importantly, why did they change back to the /61 in 1980?
For convenience, I've attached the link.
http://www.pelicanparts.com/911/technical_specs/911_chassis_info.htm
Old 09-05-2001, 07:22 PM
Early_S_Man's Avatar
The page your link points to has NUMEROUS TYPOGRAPHICAL ERRORS!!!
The 915/63 transaxle did not appear until the 1980 year model, per the factory spec book! And, they did NOT change back to the 915/61!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
Old 09-05-2001, 07:36 PM
autobonrun's Avatar
Post
thanks. That answers one of my questions. I'll let Wayne know. However, what is the difference between the 915/61 and 915/63?
Old 09-05-2001, 08:02 PM
Bill Verburg's Avatar
Post
1980 ROW type# 930/09 had 188bhp@5500, 265Nm@4200, cr 8.6, 34mm intake port(5mm smaller than Carrera 3.0 or 78-79 SC) 35mm exhaust port, vacuum adv & ret dist, improved oil pump/venturi, trans type# 915/62
1980 US type#930/07 had 180hp@5500, 244Nm@4200, cr 9.3(yes, higher than ROW), trans type# 915/63
1981 US type# 930/16 had 180bhp@5500, 244Nm@4200, cr 9.3, 34mm intake port(5mm smaller than Carrera 3.0 or 78-79 SC) 35mm exhaust port, with improvements to cis, cams advanced 6 from Carrera 3.0, trans type# 915/63
1981 ROW type# 930/10 had 204bhp@5900, 267Nm@4300, cr 9.8, 34mm intake port 35mm exhaust port, the same cis improvements, cam timing as per Carrera 3.0, trans type# 915/62
Bill Verburg
My Home Page My Pelican Gallery page My Porsche Owners Gallery Page
Old 09-05-2001, 09:14 PM
