-   -   Visor Window gap (http://forums.pelicanparts.com/porsche-911-technical-forum/789321-visor-window-gap.html)
Roswell 12-29-2013 08:33 AM
Visor Window gap
1988 Targa. Drivers side visor window leans back, with a gap that increases from the door to the top. Thoughts on how to repair?http://forums.pelicanparts.com/uploa...1388334723.jpg
Daviboy 12-29-2013 08:46 AM
Take off the door card and top and you will find one allen head bolt if you follow the vertical line down of the window. Inside the front of the door at the top above the hinges are (or should be) two black cover plugs remove them and you will see two allen head bolts in the recesses holes. Loosen them all up a bit and you should be able to get the the window back into alignment. Tighten when happy and reinstall door card and top. Bobs your mothers brother :)
Roswell 01-13-2014 09:17 AM
Davy,
Thanks for the info. Repaired the visor window yesterday with your help.
