Vulnerari Praesidio
Visor Window gap
1988 Targa. Drivers side visor window leans back, with a gap that increases from the door to the top. Thoughts on how to repair?
Take off the door card and top and you will find one allen head bolt if you follow the vertical line down of the window. Inside the front of the door at the top above the hinges are (or should be) two black cover plugs remove them and you will see two allen head bolts in the recesses holes. Loosen them all up a bit and you should be able to get the the window back into alignment. Tighten when happy and reinstall door card and top. Bobs your mothers brother
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
Vulnerari Praesidio
Davy,
Thanks for the info. Repaired the visor window yesterday with your help.
"Wisdom is knowing what to do next; virtue is doing it." - David Starr Jordan |
