-   -   70-71 engine compartment wiring questions (http://forums.pelicanparts.com/porsche-911-technical-forum/789412-70-71-engine-compartment-wiring-questions.html)
speedo 12-29-2013 05:18 PM
Lost my notes and diagrams. Some simple CDI wiring questions and a few more. I have deleted the need for the rear defroster. Let me ask questions picture by picture...this pair of "somewhat painted" wires comes from the front left of the engine compartment. Enters the compartment right next to the big harness bundle. Doesn't go to the rear defroster...what are they for?
http://forums.pelicanparts.com/uploa...1388364409.jpg
My CDI unit is right to the left. I have the harness for the CDI, but does this red/grey wire connect to the short red wired coming off the CDI plug? The black wire coming off the plug goes to the dizzy trigger, right? It goes to the same spade the purple black lead on the side of the dizzie connects to?
http://forums.pelicanparts.com/uploa...1388364541.jpg
And on the end of the CDI cable that goes to the coil, the yellow/white goes to one side of the coil and the braided ground goes to the other side. The braided wire has another end that gets grounded somewhere near the coil, and the black wire goes to the dizzie. Where does the second braided wire go?
http://forums.pelicanparts.com/uploa...1388364729.jpg
There are two wires that come out of the engine harness right next to the cold start for the Zeniths (which I deleted although) Do I just tie them off?
http://forums.pelicanparts.com/uploa...1388364946.jpg
There is also a red white wire in the engine harness that has been cut in several places and I could not figure out what they were originally intended for...
http://forums.pelicanparts.com/uploa...1388365065.jpg
http://forums.pelicanparts.com/uploa...1388365101.jpg
Near the 14 pin plug (still on the engine harness) there is a long spadeless yellow/blue wire that I cannot tell where it goes
http://forums.pelicanparts.com/uploa...1388365189.jpg
Finally, this wire sticking out from the front of the electrical console...has no coresponding end.
http://forums.pelicanparts.com/uploa...1388365350.jpg
This red wire coming off a capacitor (?) above the VR is bare
http://forums.pelicanparts.com/uploa...1388365437.jpg
And this grey/white wire coming into the engine compartment, in a sleeve with a double ground and a short white wire with a spade recvr?
http://forums.pelicanparts.com/uploa...1388366193.jpg
Lastly, the wires that are for the light in the decklid. I get the ground brown wire, but where does the spade pic up power? The black wire in front of the electrical console?
Might be easier for someone with a stock 2.2 to shoot a few pics of the inside of the engine compartment for me.
TIA guys...I appreciate it.
Speedo
Nostril Cheese 12-29-2013 06:00 PM
Pelican Parts - Porsche 911 Parts Listings & Diagrams
speedo 12-29-2013 06:22 PM
wiring diagrams
Yeah, I have all these and have reviewed them...but they are not clear.
Speedo
Nostril Cheese 12-29-2013 06:40 PM
Then you need to re-read them or get a hold of the actual manuals. They dont get any clearer than the factory diagrams.
timmy2 12-29-2013 07:55 PM
Looks like someone has done a lot of poor modifications to your original Engine harness...
Here is what a new CDI Harness should look like, and what new complete Engine and CDI harnesses look like:
http://forums.pelicanparts.com/uploa...1388374935.jpg
http://forums.pelicanparts.com/uploa...1388375027.jpg
From your pictures I don't think I would want to risk trying to guide you through trying to hook it up as there are some strange and incorrect things going on. The stray blue/yellow wire should be run to the 3 pin CDI connector for example...
I could build you a new harness with installation instructions ready to be mailed by next weekend. I normally charge $425 for the MFI and CDI harness together, but I will reduce the price if you want it built strictly for carbs.
PM me or email me if you are interested.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/740894-building-sc-mid-year-engine-harnesses.html
timmy2 12-29-2013 08:27 PM
Here are some pictures of a fuse panel I reconditioned for someone that may help with the cap wiring.
http://forums.pelicanparts.com/uploa...1388376931.jpg
http://forums.pelicanparts.com/uploa...1388377109.jpg
http://forums.pelicanparts.com/uploa...1388377482.jpg
timmy2 12-29-2013 09:10 PM
And on the end of the CDI cable that goes to the coil, the yellow/white goes to one side of the coil and the braided ground goes to the other side. The braided wire has another end that gets grounded somewhere near the coil, and the black wire goes to the dizzie. Where does the second braided wire go?Base of dizzy.
The yellow wire becomes energized when you turn the starter and for as long as the starter is engaged, the red/black wire comes from the Auxillary Starting Relay, they both go to the TTS (item 14 on the print) . Tape and heat shrink them .
They are probably really grey/red and go to the Micoswitch and the solenoid valve(stop) items 13 and 15 on the print. If white/red the only thng on the print is the Heated plane, item 82 on the print, but it seems as though that should be a short wire...
Near the 14 pin plug (still on the engine harness) there is a long spadeless yellow/blue wire that I cannot tell where it goesThat color combo wire normally runs from the coil positive to the 3 pin CDI plug
Finally, this wire sticking out from the front of the electrical console...has no coresponding end. check the wire color? If red, it is probably the switched power for the CDI
And this grey/white wire coming into the engine compartment, in a sleeve with a double ground and a short white wire with a spade recvr?There are a few spare wires indicated in the print, white/black for one. The white/grey on the print goes from item 52, the auxillary starting relay to item 12, the Electromagnetic control valve...
Might be easier for someone with a stock 2.2 to shoot a few pics of the inside of the engine compartment for me. Funny, the print shows a white/black wire supplying it.
Speedo
I added a few comments that may help.
COLOR FACTORY PRINTS help me...
Porboynz 12-29-2013 09:35 PM
The red and brown wires in the first photo look like the fuel pump wires for an MFI Bosch pump mounted on the shoe on the rear torsion bar tube.
pors1968 12-30-2013 06:01 AM
red and Brown fuel pump for cis
speedo 12-30-2013 04:41 PM
Thanks for the constructive suggestions...
The Bosch fuel pump is already wired up. The brown and red wires in the first pic must be for something else. Let me ask a few questions and whittle away at the wires. First and easiest. The lid light wires. Brown I get, power is taken from where? Little spade sticking out from under the console? CDI harness has the correct blue yellow wire already which goes to the coil. I understand that the braided wire goes to the coil also. But the braided wire is extended another 8 inches past where it connects to the coil. Is that extension viable? What could it have gone to? Maybe AC compressor at some point. Since the CDI has it's own blue yellow wire (heavier gauge, then the blue yellow wire smaller gauge) sticking out near the 14 pin must go somewhere else. And ...it doesn't appear on my diagram. In fact there are no blueyellow wires I see in the 14 pin on my diagrams. I will cap off the solenoid wires, and look over the other numbered answers with my diagram in front of me.
Thanks guys. If anyone with a 2.2 has a clean engine compartment and can shoot me a couple pics of the wiring on that side, I will buy you a beer. :D
Speedo
Trackrash 12-30-2013 05:31 PM
Speedo, I feel your pain. Was your car originally a T? When I restored my '71 I ended up ripping out all my wires and just started over. I created my own engine harness from scratch, eliminating a bunch of unused wire in the process. When I was done, I had good size box of left over wires.
One problem I came across was many of the options of the period required Porsche to repeat certain wire colors (they had not started to use dual tracers on their wires yet). The documentation for items like airconditioning and gas heaters is poor. You may also have some unused fuel injection wires there as well.
You can see my engine wiring in this post, which has some good info you should check it out.
http://forums.pelicanparts.com/porsche-911-technical-forum/787769-engine-electronics-2-2-into-66-options.html
Good luck,
timmy2 12-30-2013 11:05 PM
Braided wire goes to the mount of the coil.
You can see it here in this picture of my old '73. (Boy, I miss that car...) One wire goes to the coil and the other goes to the case mount.
http://forums.pelicanparts.com/uploa...1388473364.jpg
The blue/yellow wire doesn't make sense. I have never run one in the numerous early year harnesses I have built, nor does it show up in the prints...
What is the known history of the current engine harness in the car?
timmy2 12-30-2013 11:13 PM
Better Picture?
http://forums.pelicanparts.com/uploa...1388473979.jpg
gamin 12-31-2013 04:31 AM
I would strongly recommend finding someone with 70-71 factory workshop manuals. The fold out color electrical wiring diagrams are very good. If you don't have exceptional eyesight you may need magnification. There was someone on this forum in the past that made a very nice much larger in color laminated wiring diagram for these cars. I have one and it is worth the money. Do a search.
pors1968 12-31-2013 04:44 AM
blue yellow back up light early cis harness 73-75 if i remember .RIchard
timmy2 12-31-2013 08:18 AM
Back up wires are green/yellow and grey.
speedo 12-31-2013 05:46 PM
Headway
Thanks to you guys, I have buttoned up most of the wiring. I did go back to the diagrams.. and sorted through the 14 pin connectors,
http://forums.pelicanparts.com/uploa...1388540130.jpg
And this...was not so helpful
http://forums.pelicanparts.com/uploa...1388540189.jpg
So I have three remaining questions...
The three hole plug wired to the underside of the panel is for the rear defroster?
This is a noise suppressor?
http://forums.pelicanparts.com/uploa...1388540359.jpg
And this wire which with age looks like a grey/white, or brown/white goes to the rear defrost relay?
http://forums.pelicanparts.com/uploa...1388540475.jpg
Other than that, the CDI harness is in place...just waiting for some new shrink tube. The warm-up solenoid wires are gone and the yellow blue wire in the engine harness has no purpose...it is here
http://forums.pelicanparts.com/uploa...1388540668.jpg
But not here
http://forums.pelicanparts.com/uploa...1388540722.jpg
Thanks for helping me wrap this stuff up SmileWavy
