is a '79 tach current triggered or voltage triggered?
Not even sure I know the difference. But if someone can answer this...I may finally be able to start hooking up the MSD ignition. http://www.pelicanparts.com/support/...s/a_frusty.gif
------------------ Jeff '79 930 http://www.pelicanparts.com/gallery/jkcrewsn |
You will need a MSD tach adaptor to make the tach work
Ground triggered divided by six in tacho?
Breaker points ground themselves -> Pulse in tacho -> electrifies the magnetic coil that moves the tachometer pointer -> faster pulses, higher revolution display at tacho. Just a thought http://www.pelicanparts.com/ultimate/smile.gif |
Britwrench. Ya, but the wiring diagrams supplied with the tach adapter comes with either voltage or current triggered. I guess I will just wire it the way it looks like it will work. Thanks.
| All times are GMT -8. The time now is 01:22 AM. |
