jkcrewsn's Avatar
Post is a '79 tach current triggered or voltage triggered?
Not even sure I know the difference. But if someone can answer this...I may finally be able to start hooking up the MSD ignition.
Jeff
'79 930
http://www.pelicanparts.com/gallery/jkcrewsn
Old 09-05-2001, 04:34 PM
Post
You will need a MSD tach adaptor to make the tach work
Old 09-05-2001, 09:42 PM
Senior Member
Zendalar's Avatar
Post
Ground triggered divided by six in tacho?
Breaker points ground themselves -> Pulse in tacho -> electrifies the magnetic coil that moves the tachometer pointer -> faster pulses, higher revolution display at tacho.
Just a thought
Old 09-05-2001, 10:40 PM
jkcrewsn's Avatar
Post
Britwrench. Ya, but the wiring diagrams supplied with the tach adapter comes with either voltage or current triggered. I guess I will just wire it the way it looks like it will work. Thanks.
Jeff
'79 930
Old 09-05-2001, 11:54 PM
