nene's Avatar
Windy sound at 50 mph
When driving above 50mph in my 86 Carrera, I begin hearing the mighty wind from my front windshield. I can push (from the inside) on the windshield and it moves (lose). The car at some point had a window out paint job, so I am thinking that they did not reinstall it correct. What to do?
Serge
Old 01-02-2014, 11:33 AM
How long have you had the car? Did it just start doing this?
First thing to do is to make sure the molding is in the grooves and sure you have the right glass and seal for your car.
You can either buy an new seal and replace it, or add some rubber stripping in between the glass and the seal, or frame and the seal.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-02-2014, 11:46 AM
Fleabit peanut monkey
Bob Kontak's Avatar
What snbush says.
If you do replace the seal, I have read where the best choice is the factory piece.
It is not a hard job but dig up a friend that is comfortable working on cars for the rope pulling procedure.
1981 911SC Targa
Old 01-02-2014, 01:21 PM
nene's Avatar
I have had the car for 6 months and its been doing this since then. The metal molding appears to be in its correct place. If I push the windshield from the inside when driving, I can hear more wind coming through. I think I might take the plunge and reseal it, but already worrying about breaking it.
How could the window be this loose? What purpose does the molding serve?
Old 01-02-2014, 01:31 PM
You can push a 911 windshield out by hand very easily, so don't push too hard. The molding locks into a groove in the seal and gives it some stiffness/support.
I would replace the seal with a genuine Porsche seal. HAve a glass shop that knows the ins and outs of a 911 do the work. Have them make sure that the trim is shaped correctly before it goes back in. I wouldn't drive the car in the rain until it gets fixed.
JR
Old 01-02-2014, 01:51 PM
The glass floats within the seal, so over time the glass has probably been pulled down by gravity, the seal may be worn or disfigured. My guess is the air is coming through at one of the corners, likely the passengers side. Try moving the seal with your fingers, or using a wooden wedge and mallet to force the seal out onto the frame, be careful because older windshields are brittle and break easily. To loosen the seal you can try sliding a credit card between the seal and the glass, you might then be able to move it if it is stuck in place. If you post a picture of your wind shield it might help to diagnose.
Old 01-02-2014, 02:01 PM
Obsessed
sobamaflyer's Avatar
Drive faster to hold the windshield in better
Seriously, the windshield in these puppies is incredibly [disturbingly] easy to remove. FWIW a glass shop isn't going to guarantee the work or the existing glass.
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 01-02-2014, 02:09 PM
