1974 Suspension bolts
I recently removed my suspension to perform some clan up, replace worn parts, etc. I am wondering can I reuse my suspension bolts? Will they torque properly or should they be replaced?
Thanks DRC |
Max Sluiter
I would replace them but if they don't have any corrosion then you could reuse them. The long bolts for the crossmember are probably the only ones where you can't easily buy a replacement.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Fleabit peanut monkey
I believe the only stretch bolts in the older 911's are the connecting rod bolts.
That said, if not beat up/corroded, have them plated and they will look pretty spiffy and still do the job.
1981 911SC Targa |
I only changed the ones that were beat up, rusted or otherwise ugly. I did replace most of the washers for the same reason.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Thanks guys I was hoping that was going o be the answer.
