78 SC Targa Interior Pull Switches
I own a 78 Euro SC Targa.
I am wondering what the expected illumination is for the interior defroster and fog light pull switches are when the headlight switch is on?
Right now when I turn the headlights on neither the fog light or defroster pull switches illuminate. When I pull the switches they do illuminate.
In the case of the fog light switch, when I turn the switch clockwise it will illuminate but not turn on the fog lights (what is the function of this?). If I pull the fog light switch it will illuminate and turn on the fog light switch.
I have the 2-step defroster pull switch. Should it light up differently for each step?
Thanks....
Old 02-03-2014, 09:18 AM
Fleabit peanut monkey
Bob Kontak's Avatar
My 81 Owners manual states that the switch knobs only illuminate when the circuit is energized.
Here is something I just learned and I bet (hope) you have your knobs confused, The defogger function is engaged by pulling the knob and the mirror defroster is engaged by turning the knob to the right. Either of these will kick in the defrost switch light.
Fog lights only work when knob pulled and only when low beams are on.
Did not see mention of two pull steps for either knob.
1981 911SC Targa
Old 02-03-2014, 10:01 AM
My defogger pull switch definitely has two steps (or positions). I read that there are both single position and two position defogger pull switches. My defroster pull switch only illuminates when pulled when the headlight switch is on. I have read that the pull switch should be illuminated even when the switch is off and the headlight pull switch is on?
Also, my fog light pull switch can both be both pulled and turned clockwise. I have no idea what the fog light switch is supposed to do when it is turned. My fog light pull switch illuminated when turn clockwise. It also illuminates when it is pulled. I have read that the fog light switch should illuminate in the off position when the headlight switch is on.
So I am trying to figure out what the intended illumination function should be for my car and my year.
Old 02-03-2014, 10:19 AM
Do they all have mirror defrost ?
Jimmy Foster
78 911 SC
Old 02-03-2014, 10:24 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
Turning the foglight switch should energize the rear foglight (not present on US cars, though the wire is still there).
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 02-03-2014, 12:07 PM
Rescuer of old cars
Arne2's Avatar
Later cars must be different. In my '84 (US) both switches are illuminated dimly whenever the dash lights are energized. Turning on the (worthless) fog lights or the rear defroster makes the switch glow brightly.
Also, the 2-step switch for the defroster on mine works light the OPs fog switch. Pull to turn on the middle section of the defroster grid, twist to turn on the upper and lower sections of the grid as well.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-03-2014, 12:19 PM
The fog light pull switch turning clockwise makes sense now. My sc is a euro model so they came with a red rear fog light.
So it seems to me that on a euro 78 sc targa the fog light pull switch and the defroster pull switch do not illuminate when the headlights are on.
Old 02-03-2014, 06:12 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
I can test mine tomorrow...
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 02-03-2014, 08:32 PM
That would be great!
Thanks...
Old 02-03-2014, 09:14 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
That's the way my '80 works. No fancy stuff until the Carreras.
Dru
Old 02-03-2014, 09:28 PM
nineball's Avatar
83SC - both fog and defrost are on when the lights are on and brighter once engaged.
Which interior switches illuminated? 84 Targa
in doing some research for my double activated defrost switch i found that the first pull out activates the middle defrost area, turning it does the top and bottom of the rear window. never tried turning the fog switch but since i don't have a rear i guess it doesn't matter much.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 02-04-2014, 07:40 AM
porwolf's Avatar
Here is a page of my US 1979 SC manual re. fog light and defroster switch functions:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-04-2014, 03:19 PM
acapella8's Avatar
Confirmed - turning the foglight switch energizes the rear foglight with 12v.
[GruppeB # 978]
Old 02-04-2014, 03:55 PM
acapella8,
Your fog light and defroster pull switches don't light up when the headlight switch is on right?
Old 02-04-2014, 06:14 PM
acapella8's Avatar
Correct. Also, I'm sure you've noticed the "euro parking" option. The turn signal is wired to turn on left hand side markers and left brake lamp. Engage left hand turn signal all he way down with no key and no switches on. I understand it was a parking "safety" feature for euro destination vehicles.
[GruppeB # 978]
Old 02-04-2014, 08:31 PM
Rescuer of old cars
Arne2's Avatar
My '84 US car also has the above mentioned "parking" light (single side). As I recall, Porsche (unlike other makes) included that in their US cars as well as the RoW cars.
2018 718 Cayman 2.0
Old 02-04-2014, 08:44 PM
acapella,
What lights up on your ventilation control panel (the 3 lever control unit)?
Mine seems to have the defrost off and defrost max lit up. I am also missing the icon on the upper left of the control panel, what does your control panel have there?
Old 02-04-2014, 09:46 PM
ROW '78 911 Targa
timmy2's Avatar
Nothing in the upper left on my '78 Euro..
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-04-2014, 10:34 PM
acapella8's Avatar
acapella,
I can take pic when I get back to my garage showing illumination or lack therof.
I did NOT know that US models had the "Parking light" option, I thought that was unique to ROW models, but I learn something every day..
[GruppeB # 978]
Old 02-05-2014, 06:00 AM
Thanks.
I have been going through the car replacing light bulbs. While doing so I wonder about the operation of some of the lights.
Next on the list is the seat belt and emergency brake warning lights. What does your red warning light say on it? Fasten Seat Belt / Brake? Does your seat belt warning light stay on for maybe 5-10 seconds and then automatically turn off? What about the buzzer sound? Is it a faint buzzing?
Old 02-05-2014, 07:26 AM
