I've read a lot of old threads on sputtering problems but none seem to describe what I'm experiencing. It's an intermittent problem, but when it occurs it's very noticeable and renders the car extremely difficult to drive. When both accelerating and cruising at a constant speed, the engine will stick at a certain amount of revs (usually between 2300 and 1300), and quite often will also drop down incrementally. If I keep my foot down, it'll usually jump up incrementally by a few hundred revs, each time often accompanied by a very odd "Choo" sound coming from the passenger side rear. A fairly significant bucking can sometimes accompany both the drops and the jumps. Then it'll disappear for a bit, only to come back just as bad anywhere from seconds to minutes later.
I've never tried to see if the car will eventually stall, but quickly engaging and disengaging the clutch seems to sometimes temporarily stop the problem, as does pushing the accelerator to the floor. I've never noticed the problem from cold, the only two times it's happened it occurred after the engine had some time to warm up, with several trouble-free drives between the two. I've decided to winterize and garage it for the rest of the winter until I can get a handle on what's wrong and how many body parts I'll have to sell to fix it. I had initially thought it could be a fuel system issue, but a trip to my local garage for another unrelated problem turned up a potentially broken head stud or studs. Could a vacuum leak cause such severe symptoms? I haven't had a chance to check out the flywheel sensors that many other threads have talked about (it's a little cold up here), but from what I've read a sneezing noise isn't associated with their failure. Another possibility I've kicked around is the result of an embarrassing newbie moment (documented on this board for my eternal shame ), in which I dumped an extra quart of oil into the tank based on the gauge in the dash without checking the dipstick (though the car was warm and level...I swear). Still, I have a hard time believing that one quart would cause such dramatic symptoms.Hopefully all that makes some sense. Has anybody experienced a similar issue or have an idea as to what I'm experiencing? Any help would be awesome.
-Taylor 1984 ROW Carrera Let's go Tech! |
I had a similar problem on my 3.2 Carrera. It turned out to be the RPM sensor. I got a kit with the RPM and TDC sensors here on Pelican, and that cured the problem!
Ok, I'll check that out once it warms up around here. It drives perfectly when it's not experiencing the problem, so I'm reasonably hopeful it's sensors and not actual engine damage. I'd tackle it this week but I head back north for my last semester on Wednesday
Anybody else have an idea?
Can be as simple as the DME relay about to fail (intermittent loss of fuel pressure) or the speed sensor on the engine. Get the spare DME relay in any case. And the sensor is only around 90$.
To answer your other questions. - a quart of oil is very unlikely to cause what you are seeing. The dipstick from lowest to highest mark is at least 2 - 3 quarts and overfilling has other symptoms (once you suck oil into the intake you blow a lot of smoke) - a snapped head stud doesn't do much. Many drive around with these for a long time and don't even notice it. So I doubt that is your issue. So no body parts (yet)
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
...I've had a fresh DME Relay in my glovebox for months, just never thought to try it. I'll try those sensors too, if they're anything like the rest of the electrics I'm sure they're in a bit of a state. Just so I'm clear though, you're talking about the two flywheel sensors (911-606-215-01-M14), correct? Seems like everyone has a different name for them.
Yes Taylor,
correct on the flywheel sensors. There are two identical (part number wise) sensors. One is called the engine speed sensor and looks at the fine toothed area of the flywheel. The other one is the reference sensor. It looks at the single metal pin on the flywheel. If one is bad it's a good idea to replace both. However, it's the speed sensor could cause your symptoms. An intermittent reference sensor is by far less obvious because it is only used at certain conditions. If you search the forum there is a BMW replacement part for about half the price of the Porsche part. They are the same item so get the BMW version and safe some cash. ingo
Retired, finally
If you're going to replace the 2 reference senders (as I did 3 months ago when my 84 died at the track), I recommend you also replace the cylinder head temperature sensor, while you're in there. It's a fiddly place to work, and all 3 wires end up having to go through the same grommets.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
I've used these BMW parts for the speed and reference sensors. They are a direct replacement.
Pelican Parts - Product Information: 12-14-1-708-619-M14 Mike
The more I learn, the less I know. |
Subcribed - let us how how it works out.
1986 3.2 to 3.4 conversion |
Chain fence eating turbo
Read my horror story called something like "running my Carrera3.2 off a cliff". Same symptoms I never figured out after 6 months of testing every component in the EFI chain........most more than a couple of times......
Sputtering, bucking, sneezing??
Sounds like a Journey song. |
It'll be at least a month until I can get down to it, but I'll update when I do. Thanks for the interest. Quote:
Now I've got Lovin' Touchin' Squeezin' stuck in my head...thanks
RETIRED
Sensors, check threads on compatible BMW sensors for the 3.2....they be 1/2 price. John Walker has the part numbers.
The bucking could also be a fuel filter.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Could also be bad/cracked solder joints within the DME usually near the coil drive transistor. I've repaired dozens of these DMEs in this area and often it causes erratic coil signal.
Bad Ref and Speed sensors usually cause no start issues, simple test for these is resistance/ohm testing them for 1000ohms +/- 10%. Other sensor is the AFM carbon track wears out this can be tested in car with DC volt meter, search around and you'll find a writeup on howto do this. My suggestion is replace the DME relay then if possible lend your DME to someone with a 84-89 3.2L to have them test it in a known good car.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
When my '89 3.2 did this, it was an intermittent bad temp sensor.
Cheers, Jess |
RETIRED
Unless you are made of money.....throwing parts at it can get pricey. The parts can be tested.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 01-08-2014 at 09:16 PM.. |
Check the idle microswitch. Procedure is in the workshop manual.
Dave 2014 Cayman S (Awesome car!) 1991 911 Carerra (Semi Refined fun) 1986 911 Carrerra (Raw fun) sold 2001 Boxster S (Refined fun) sold |
