Engine number confusion!
Dear all,
I have found an engine with the following number: 6530689
I used this site, since I found it in a similar topic: Porsche 911 Fahrzeugidentifikation
I just want to double check the results with someone....
6 - six cylinder (ok that's obvious)
5 - 911 TV ( what does Tv mean?)
3 - from a 73
0689 - then no idea
motor should have - 130/5600
can anyone check if I am decoding this right?
also should the motor be an injection or carb model?
Thank you and sry for the boring question
Chassis87
Old 01-10-2014, 06:47 AM
Originally Posted by Chassis87 View Post
Dear all,
3 - from a 73
0689 - then no idea
Chassis87
Yes, you are decoding correctly.
TV indicates the engine was a T engine, carb'd instead of CIS. It is a 73 and the final four digits are the sequence numbers.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 01-10-2014, 07:01 AM
ossiblue,
thanks a million mate! all those numbers started confusing me.
Thanks!
Old 01-10-2014, 07:21 AM
