Could anyone tell me where this vacuum hose goes? 78 SC
I'm geting ready to put this engine back in and have no clue where this vacuum line goes. I bought the car already apart otherwise I would have marked it. It's a long hose . I have one for the vacuum advance already Any idea?
Thanks, Eric ![]()
Just a guess, but maybe brake booster?
Chris '75 911s Targa |
Band.
+1 (guessing) brake booster.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
non-whiner
That looks too small for the brake booster. However, I don't have a better guess.
"Too much is just enough." |
Not sure where it goes but I believe this (blue arrow) is your booster hose.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
ROW '78 911 Targa
Vacuum pod for the distributor.
California car has an EGR controller on it as well. Take a good look at this: 911 CIS Primer - Vacuum Lines
Might be canister line
The line is above the butterfly. Pulls the vacuum advance of the distributor as the high RPM require more advance.
The power brakes comes off the side of the airbox and is a larger hose 12mm. Bruce |
As usual Bruce nails it!
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
I'm thinking it could be for the air injection. But now I'm not sure if I got them mixed up. In this first picture the red arrow is pointing to the port/ hose that is going to the vacumm advance. Is this right or should I use the other port?
As said above it looks like it's above the throttle plate so it should be ok there? Then I'll just cap the other port. ![]() ![]() Air injection part not being used. ![]() Thanks every one for the replys, Eric Last edited by Eric D.; 01-12-2014 at 02:53 PM.. |
ROW '78 911 Targa
As Bruce stated like I did earlier, the line you are asking about is for your distributor. Take a good look at the drawing, you will figure out where all the lines go. Hint: the yellow one from the WUR goes to the opposite side of the TB on the rear bumper side of the car. (dotted lines)
No EGR.......
I don't think the engine is using an EGR based from the picture attached. The EGR uses both connections and one (1) port it is plugged (see picture above). Below is the EGR with hoses going to the throttle body: ![]() ![]() Plus the hose in question is too long to be used for the EGR or distributor. If I have to guess, it might be coming from the carbon canister like someone earlier mentioned or to the smog pump (?). I have removed my smog pump and has not seen an SC engine in a while with a smog pump in place. Tony Last edited by boyt911sc; 01-12-2014 at 07:48 PM.. |
It couldn't be from the carbon canister, that would be a source of unmetered air correct?
You are indeed correct........
ROW '78 911 Targa
Just look at the drawing,. IF there is an egr then one of the 2 ports would be used for the egr and the other would go to the bottom of the egr and then to the distributor....
As the one port is plugged I would assume no egr so the line goes to the distributor vacuum canister. Last edited by timmy2; 01-12-2014 at 10:22 PM.. |
ROW '78 911 Targa
I guess a picture speaks 1000 words... Follow the line back from the distributor (device #6)
If no EGR, then just delete the lines to it (device #7) and it will be a direct line to the dizzy...(plug the other port)
ROW '78 911 Targa
As pictured:
Smog Air pump line (8) comes from the front lower port, Top WUR line (yellow) comes from top front port. Vacuum advance comes from rear port left, and lower WUR line (blue) via vacuum control (decel) 9, and Thermo Valve 4, comes from rear port right.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 01-12-2014 at 10:35 PM.. |
I printed that diagram last night. No EGR. But I did mix them up. My vacuum advance is at the smog air pump line. I don't think it matters though since they are both ported vacuum? (above the throttle plate)
Dennis thanks so much. Your a big help as always. Last edited by Eric D.; 01-13-2014 at 04:32 AM.. |
