A few questions if I may....
1981 SC not starting, fires if I spray starter fluid in the POV port. Both yellow wires on starter good . With CDI disconnected and test light on yellow wire and ground on the TTS , crank over I get voltage. I disconnected connector at CSV and inserted modified spade connectors in the socket, hooked to test light, crank over,...No voltage ![]() Can I jumper the TTS and try again to prove the TTS bad? Is the TTS a common part to other CIS systems, Volvo, Mercedes,(junk yard) or specific to the 911? The TTS yellow post reads 24 ohms to ground , the other post reads grounded, also 24ohms post to post. Thanks for any suggestions,Steve
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Fleabit peanut monkey
TTS is the caboose in the system.
I am going to say some stuff you probably already know so just roll with it. Starter -> CSV -> TTS-> ground. Crank starter. Juice goes thru CSV and is at TTS asking if it can go to ground. If 25C TTS says, Hell yes, come on thru. At 36C the door is closed. I would take the yellow wire at the TTS and alligator clip it to ground. Bypasses the TTS but will only be "live" when the starter is cranking.
1981 911SC Targa |
I may be mistaken but when I was having the same problem and wanted to determine if the TTS was working, in order to bypass it, I grounded the red/black TTS wire which comes from the CSV looking for ground. I believe the yellow TTS wire powers the heater in the TTS that limits - through the TTS- the CSV to a max run time of 8 seconds - under the coldest conditions - so as not to flood the engine.
In addition, if no power at CSV it could be not getting current through the yellow wire coming from the starter. Just my thoughts, certainly not the expert! Dave 1982SC |
The CSV get's power every time you try to start the car. The CSV needs a ground to operate. It get's it's ground from the thermo time switch when the temperature is low enough to need the extra fuel. The yellow wire (coming from the starter) on the thermo time switch applies power to the switch heats a bimetallic spring inside and breaks the ground after 8 seconds of cranking. So you see, the cold start valve is controlled by ground not power like most circuits.
Than you all for your input ! Perhaps putting a lead in each socket of the CSV cable was not the right way to verify that is was receiving power? No ground? I'm more of a nuts and bolts guy , trying to absorb this
![]() Thanks again!
I am subscribed. Steve, resistance on my 81's TTS is 24.9 ohms.
1981 911SC Targa |
Thanks Bob! Sounding like the TTS maybe OK? Looking forward to understanding this critter
Click link,for a diagram. Thermo Time Switch 1978 SC 3.0
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 10-01-2016 at 04:48 PM.. |
Locating old posts.....?
Larry,
Thanks for the link. I am not computer savy like most of you and I could hardly locate my old posts in this forum. Tony |
