1983 911SC Won't Start
My '83 911SC has been run very little this year. It started and ran fine about six weeks ago, but now, I can't start it. It turns over normally, and "catches" (starts briefly...about a second) then dies on me. Anything jump out as something special I should check such as a sensor, etc? Never had trouble with this before. Also, the warm-up regulator was replaced a couple of years ago. Any advice is appreciated.
RETIRED
Air fuel spark. Check fuel by spraying ether into the intake. Sounds like the fuel pump maybe be on it's last legs.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Get a helper and connect a spare, grounded spark plug too one of the plug wires and crank engine. Have helper watch spark plug to determine if you have spark. Very common for the CDI unit to intermittently/spontaneously die.
Thank you both for your suggestions on where to start. I thought it might be good to check if there was a frequent problem with a sensor or something. Makes sense to start with the basics.
Banned
Subd.
grateful user
All the above, except for the ether part. Prime it up by lifting the flapper. Prob just to high of control press. to bust off.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Had the same issue with my '83 a few weeks back. Used the great help from the board to solve - dead CDI. See my thread. Suggest you do the spark test first. Good luck!
Fuel injection system........
Banned
Ossiblue on the rescue.........
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
