Battery charging or trickle charging two batteries
Sorry if this has been asked before. I did try searching the forum first. What is the proper way to connect a charger to a two battery 1970 911T? Do you just connect to one of the positive terminals and one to ground? Thanks very much!
RETIRED
Pull them out and charge on the bench. Once charged a trickle charger will maintain them, assuming they are in good shape.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
ROW '78 911 Targa
Yes.
Are we talking two 6 volt batteries in series or two 12 volt batteries in parallel? Previous would be my guess based on vintage.
Fleabit peanut monkey
Little battery compartments in the inner fenders. One on each side. 6V each. A pal has a 70T so I seen them with my own two eyes.
1981 911SC Targa |
Yes. There are two batteries. One in each side of fender. The batteries are marked Interstate U911-50. I didn't see voltage. Possibly as you say 6v wired in parallel. Would hooking up trickle charger on one take care of both? Thanks!
They are both 12 volt. And hooking up the trickle charger (Battery Tender?) to one will keep both at the proper charge level.
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
NO - 6 volt X 2 wired in series as wwest says. Doubles the voltage.
6 volt in parallel would give 6V but be a long lasting battery vs a single one. Connecting Batteries in Series or Parallel However, it could be either, depending on how wired. Believe original was 6V in series.
1981 911SC Targa |
RETIRED
Should be 2, 12v batteries on each side for weight and balance.....early short wheel based rides also had lead ballast up front if I recall.
Alternators are not designed to charge batteries but to maintain charged batteries. 110v chargers should be used to bring a good battery to 12.8v+....trickle chargers should be used to maintain batteries in rides that sit more than 2 days or more. Just my experience.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 01-16-2014 at 08:08 PM.. |
6v battery has three filler caps not six
I think that maybe I'm dreaming.. |
Very few John Q Publics (some do) would make the mistake of hooking 2 lead-acid batteries in parallel, let alone Porsche design engineers. |
Connect 2 lead acid batteries in parallel = asking for an ..... EXPLOSION Cell shorts, goes flat, in battery "A", battery "B" begins dumping FULL CHARGE into battery "A", Electrolyte in battery "A" begins to boil...OUTGASSING...small spark... BANG! Plus it is a practical impossibility to fully charge 2 lead acid batteries connected in parallel. |
In my ~55 years of driving I have jumped, or had jumped, LOTS of otherwise DEAD car (tractor) batteries. I was NEVER advised, and have NEVER advised anyone, to use anything but the automotive electrical system to bring the jumped battery back up to standard charge level. Automotive battery charging systems, voltage regulators, are designed specifically for recharging a dead lead acid battery at a controlled rate, raising the target charge voltage as the battery charge level rises so as to not overheat the battery during recharge. |
ROW '78 911 Targa
Interesting thing about having the factory prints to reference is they show the 2 positive posts tied together and the 2 negative posts tied to the chassis.
Parallel connection, so a trickle charger on one battery will charge them both. (Eventually) Print number SL35 for those that are interested.... Last edited by timmy2; 01-16-2014 at 10:02 PM.. |
using the car alt just puts a strain on it. everyone at one point in their life has jumped a dead battery then driven the car. it is better to use a battery charger. that way you KNOW the battery is fully charged.
you better talk to FORD. my daughters F250 has 2 batts in parallel. batteries can "run away" or start self charging. put a meter on one. you will see the voltage much higher than 12v. i have to deal with a LOT if UPS at work. one has 40 batteries that puts out 480v and 40Kva. you will see the batterieis swell. when they have done that, they have probably self charged. i saw one at 18v one time.
My 70 came from the factory with 2 12v batteries in parallel. The U911-50 battery is a 12v made by interstate and fits the battery boxes. May not be necessary but I use a separate trickle charger for each battery.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Like electrolytic capacitors, these will generally have some sort of one-time pressure relief valve. A completely discharged lead-acid battery will initially present an extremely high internal resistance oftentimes resulting on a an unusually high terminal voltage to bring the battery back up to the level required to begin accepting a charge. I have seen it take up to 2 days to complete the cycle. Last edited by wwest; 01-17-2014 at 08:58 AM.. |
Unless by a miracle me and my pal Larry are the only ones that know the real truth, and these other guys, like gamin who owns a 70 are clueless, I would defer to the 12 volt in parallel. 12 V in series would be 24V. Did any of the 356's have 6v systems or 2 X 6 in series?
1981 911SC Targa |
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
