-   -   Open Lug Nuts (http://forums.pelicanparts.com/porsche-911-technical-forum/792509-open-lug-nuts.html)
jac1976 01-19-2014 12:04 PM
Open Lug Nuts
I have searched extensively, but would like some opinions on specific products. Does anyone have experience with Track Studs? Out host sells Rennline (obviously a very reputable company), but I almost am certain that I read somewhere that some people had fitment issues due to the radius of the seat. Thoughts? These will be used on a street driven original 73 T with Fuchs.
Shuie 01-19-2014 04:42 PM
You need the ball seat vs. cone seat lug nuts. Here's a pic:
https://lh3.googleusercontent.com/-L...2/IMG_1346.jpg
I don't know anything about the studs you mentioned. Pelican sells the normal studs that can be pressed in. If Pelican doesn't have them you can get them from someone like Paragon. Same for the lugnuts.
Craig_D 01-19-2014 05:19 PM
Hi jac1976,
I'm running the Rennline steel open-ended lugs and have had zero fitment issues. I'm using Fuchs 7+8/16 and the lugs are perfect.
http://forums.pelicanparts.com/uploa...1390180752.jpg
Craig_D 01-19-2014 05:21 PM
Here's a closer shot from that image:
http://forums.pelicanparts.com/uploa...1390180887.jpg
jrbennett 01-19-2014 07:02 PM
I'm using stock VW/Porsche steel lug nuts. Part number N-020-112-1
I think they are the same as the Rennline ones
