SPACERS , please help
Hello, i would like to get spacers 21mm and probably 43mm or so, my friend needs a pair of 7mm. Where is the best place to buy these spacers and what do you recommend ( brand, type, etc.. ) ?
There is some spacers on Pelican but it seems very expensive, any other places or website to get these cheaper ?? Thanks i advance for your help. |
i bought the ones from pelican. i installed the one inch version in the rear and the quarter inch in the fronts...
before after another view
1987 Carrera Targa |
is this aluminium 6061 Spacer ?
on my invoice it lists the part number as PEL-WS-001 I inch Wheel Spacer Adapter
heres a link to the page...just scroll down to the bottom.
http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_suspen_main.htm
Robert Stoll 83 911 SC 83 944 |
It seems that spacers ( 21mm and + ) below 100$ /pair is virtually impossible to find anywhere, except maybe used.
And i don`t want to stack 2, 3 spacers together. I prefer having only one installed, i heard that it`s better to only have 1 spacer set-up and not stacked spacers. Thanks for your help guys, i will continue my search |
You can find Boothe in the back of excellence mag, but im sure if you e-mail wayne he can get them for you at the same price Boothe sells them and you would support the bbs, be prepared, i spent almost 150 each for 3 inch spacers and a 100 each for 2.5, but i didnt want someones cheap junk on my car that I have tendancy to bang corners with, what you can do is be a little more spacific with what your trying to do, what wheel and offset and what car wide body narrow body, or even do a search on spacers, Kevin
For 150$ each, the studs i included i guess ?
the spacer will be the same as the picture above of the black spacer, it actualy looks like a boothe piece and it comes with spacer , studs mounted and the lug nuts to bolt it to your car, you will use your stock lugs to bolt the wheels to the spacer, just remember to re check them after a few miles, Kevin
Anybody knows if it`s worthy to order it from Europe ?
Thanks. |
