-   -   Is my transmission falling off? There are no dumb questions. . . (http://forums.pelicanparts.com/porsche-911-technical-forum/793766-my-transmission-falling-off-there-no-dumb-questions.html)
Jerome74911S 01-27-2014 02:30 PM
While doing random maintenance, I noticed that there are gaps at the top of the rubber transmission mounts, where they meet the car's 'body'. I checked the torque on the mount bolts and they were good. I thought the bolts might be too long, so I removed one of the bolts and it shows no sign of bottoming out. I replaced it and torqued to 58 ft-lbs.
I notice that both the engine mounts, as well as the transmission mounts seem to indicate a slight forward tilt to the engine/transmission unit, which I imagine could be explained by the trans mount being too low for some reason.
Is what I'm seeing here normal? If not, what's wrong? The mounts are 2 or 3 years old.
http://forums.pelicanparts.com/uploa...1390861546.jpg
Davz912/911 01-27-2014 02:57 PM
I guess the $50k question is are you getting any movement? Put a jack under the
cross brace and check.
Good luck,
Dave
gamin 01-27-2014 03:08 PM
Isn't there supposed to be a heavy thick washer in there?
porwolf 01-27-2014 03:46 PM
Have you checked this? From the '78-83 PET KATALOG:
The left assembly is from a Turbo, the right one from an SC.
http://forums.pelicanparts.com/uploa...1390866333.jpg
ischmitz 01-27-2014 07:14 PM
Jerome,
I agree it looks "funny" but I believe it is normal. I noticed mine looked the same when I put my engine/tranny back in a couple of weeks ago. I have sport mounts that are about a couple of years old.
I eased my mind when I confirmed the shift rod is centered in the chassis hole. If the tranny was sagging by an inch as your picture suggests the rod would be off-center causing the shift coupler to touch the bottom of the tunnel.
Cheers,
Ingo
tirwin 01-27-2014 08:52 PM
Ok... Following up with my own dumb question. From the picture above, if there is no contact between the bracket (part 1A) and the chassis above through the mount then why do people debate the differences in transmission mount stiffness? If that rubber isn't coming into contact with anything then it's not dampening any vibration, right? Maybe there is more going on that I'm not seeing...
ischmitz 01-27-2014 09:00 PM
The rubber is molded to a metal center tube that is clamped hard to the chassis with the main mounting screw. The outer body of the mount is secured to the cross-member. The rubber provides lateral and vertical play of the transition and isolated vibrations to the chassis. The transmission will twist slightly due to the rotational moment from the engine.
Some replace the rubber mounts with full-metal versions to improve shift precision at the expense of more chassis vibration.
Ingo
Jesse16 01-28-2014 06:38 AM
Normal, you're tightening on the metal sleeve same as the rear motor mounts. Rubber is between that sleeve and the outer which attaches to the body or tranny mount. Have to push up on the motor to see if the rubber is worn, not likely in 3 years.
Flojo 01-28-2014 07:07 AM
@Jerome: these mounts are worn and tired. change.
no sir.
SC is same as left in the PET-grafik. Right grafik is earlier models, a sort of one-part-bridge.
here's my 79 SC (FIN-PET-check reveals exact parts as in grafik below)
http://forums.pelicanparts.com/uploa...1390921615.jpg
http://forums.pelicanparts.com/uploa...1390921645.jpg
JJ 911SC 01-28-2014 09:35 AM
Yes...
1: SC
1A: Turbo
KTL 01-28-2014 11:37 AM
Correct. There are four large washers used on the trans mounts and four on the engine mounts. Each mount has a big dished washer above and below the mount.
john walker's workshop 01-28-2014 11:56 AM
only 87-89 G50 carreras had a top washer. lets see a shot of the bottom. post #9 shows the clearance between the washer and the mount with new rubber. when they get old and saggy, the washer gets a lot closer to the mount. same with engine mounts.
KTL 01-28-2014 02:45 PM
Interesting on the washer count. '83 and '86 PET pdf diagrams say 4 washers for the engine suspension, 4 washers for the transmission suspension.
I have four on my '79 (not even remotely stock), four on my '87 and have seen four on pretty much every other one i've serviced. Probably a dozen in our local circle of friends cars. Weird.
Jerome74911S 01-28-2014 03:04 PM
Here's a shot of the bottom as best as I could do. Although the rubber is squished thinner on one side, it doesn't look too bad, does it?
http://forums.pelicanparts.com/uploa...1390949959.jpg
This is a shot of the topside of the engine mount. Same age as the trans mounts, about three years.
http://forums.pelicanparts.com/uploa...1390950086.jpg
Jerome74911S 01-29-2014 12:32 PM
This is a bump.
I posted the pictures above, as requested. Possibly it is clear enough that there is a forward slope in the engine/transmission unit, because the rubber in both the engine and transmission mounts is squeezed narrower in the front edge, which I suspect indicates the forward/downward slope I mention.
How this relates to my original question is something I would like to understand before I spring for a set of new mounts - which might just mask some problem.
DRACO A5OG 01-29-2014 12:50 PM
If it bothers you, you can always shave down the metal sleeve about 5-6 MM so the rubber can contact the mounts.
My fanatic track buddy and others did this to their 3.2's. I cannot say if this will improve anything but they seem to think so. I can see how it will reduce slop or twist and allow a more precise shift on turns.
But to answer OP, No it is not falling out.
schumicat 01-29-2014 01:40 PM
that does seem like a lot of squishing. you can get the factory cabrio/sport mounts which are stiffer. the all metal ones are good for track cars but I wouldn't put them on a street car.
bfunke 01-29-2014 02:59 PM
Is your top washer upside down?
Jerome74911S 01-29-2014 03:15 PM
Having the concave side up on the engine mount is the position recommended by smart people on this forum (could one of them have been Grady Clay?), whereas concave faces the rubber on the transmission, according to the same recommendation. There is discussion on this point.
The PET for my car is not clear as to position of that washer.
porwolf 01-29-2014 03:26 PM
Originally Posted by JJ 911SC (Post 7880084)
Yes...
1: SC
1A: Turbo
You are right. Sorry, my mistake:
http://forums.pelicanparts.com/uploa...1391037973.jpg
