-   -   1973 911 engine fan hub - rivet question (http://forums.pelicanparts.com/porsche-911-technical-forum/793847-1973-911-engine-fan-hub-rivet-question.html)
73pcar 01-28-2014 05:56 AM
Does anyone know the original/correct size of the aluminum rivets that secure the center hub to the engine cooling fan? Thanks!
allaircooled 01-28-2014 06:14 AM
There is a member here who restores these fans and advertises here in the classifieds. He would know. Try searching there.
allaircooled 01-28-2014 06:17 AM
Here is his thread.
Ferrino 07-04-2014 12:27 AM
Did you ever find out about the rivets?
Ferrino 07-04-2014 12:52 AM
Just noticed that Supertec sells an aftermarket fan hub which attaches to the fan with countersunk allen-head bolts and nuts:
http://forums.pelicanparts.com/uploa...1404460322.jpg
dtw 10-22-2015 02:13 PM
Bumping this - does anyone know the correct rivets for reassembling a fan?
grizzfan 10-22-2015 02:22 PM
Google or Search here for Mark Motshagen. He rebuilds these things (and did mine) and surely can help you.
Tom
mikedsilva 08-12-2017 03:23 PM
Fan rivet
http://www.ebay.com/itm/PORSCHE-ALTERNATOR-FAN-CENTER-KIT-L-W-ALUMINUM-PULLEY-/250708074497
Nice photo..
i just took my fan apart to clean and plate.. I might try to find some bolts with the correct head shape and use those instead of rivets.
Harpo 08-13-2017 05:09 AM
Dumb question here but why would you need to separate the hub from the fan. Next dumb question what is wrong with the OE fan hub? I could not find any info on the supertech web site
mb911 08-13-2017 05:19 AM
Supertecs is aluminum keeping rotational mass lower.
I regularly repair fans and fan housings for members all over the world. Most times they take the hub out becuase they want to replate the hub and use cerakote on the fan.. I know I have the mcmaster part number for the rivets somewhere but I chose to use stainless countersunk bolts like supertec does..
Below is one of my repaired fans.http://forums.pelicanparts.com/uploa...1502626723.jpg
Harpo 08-13-2017 07:22 AM
Very nice Ben
mb911 08-13-2017 08:45 AM
Originally Posted by Harpo (Post 9698233)
Very nice Ben
Thanks..
I primarily repair areas that are chipped and cracked. I specialize is welding magnesium ,aluminum, and stainless steels.. .. I then blend them to look as undetectable as possible and sand blast and paint with cerakote. The plating of the hubbis done by a local company.. Overall an inexpensive visual upgrade.
