irl irl is offline
irl's Avatar
Send a message via AIM to irl
How to tell what webers are set for??
This may be too big of a question to be answered simply and its time to dig into all the weber books gathering dust on my shelf, but thought I'd try. How do I know what a set of Webers I have will work on. I have a uninstalled 2.7 that came with a set mounted but How do I know what they were set up to run on?
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 01-29-2014, 03:32 PM
1QuickS's Avatar
The main venturi size is the key. However, a particular venturi selection may be good for a small, high reving engine and also good for a larger, lower performing engine. Even an engine of given displacement but different build specifications will want different venturis and other bits. A CIS 2.7 would like 32mm venturis but set up with S cams and similar performance upgrades then 34m venturis would be nice.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 01-29-2014, 05:32 PM
I would rather be driving
jpnovak's Avatar
Really, the only way to know is to tear them down and get the sizes for the venturies, main jets, idle jets, air correctors and emulsion tubes. The numbers are stamped on the sides of these parts.
If they have been sitting its probably a good idea to tear them down for cleaning.
Old 01-29-2014, 06:06 PM
