SC Mutt
Fog lamp switch removal
Hi all,
Had the broken, cracked fog lamp switch. Thing snapped off after I initially unscrewed. What on earth do you use to loosen the housing pictured below. I got a replacement ready to screw in but that darn thing wont budge. Any tips or suggestions are appreciated. Thanks, Gary ![]()
SC Mutt
Better pictures
At least bigger
I would take the black plastic washer with the 4 holes off first. I used a couple of forks and bent the tine and stuck one on opposite sides and unscrewed it (counterclockwise). You can also use needle nose pliers.
To remove the metal piece that broke off the switch, use a vice grip and unscrew as well. Good luck!
AJ 84 911 Targa, 76 911 Targa, 2014 Cayman S, 77 280z |
I used snap ring pliers on mine.
Chris '75 911s Targa |
If you can try to move the swicth behind the dash because black plastic washer is jam and is easy to cut the dash.
