Mex Mex is offline
Mex's Avatar
Question Valve Cover Studs
Silly question, but are the studs that secure the valve covers unique or are they the same as the cylinder head exhaust studs?
-Taylor
1984 ROW Carrera
Let's go Tech!
Old 02-17-2014, 06:13 PM
Walt Fricke's Avatar
A quick look at a parts catalog should help. For the '72-3s, the upper valve cover studs are 35mm long, the intake manifold studs are 20mm, and the exhaust studs varied from 22 (carb/cis) to 25 (MFI). Put the book back before I reread your question so I didn't check to see if the exhaust cover studs were the same as the intakes.
Old 02-17-2014, 10:05 PM
Mex Mex is offline
Mex's Avatar
Thanks, I ended up doing the same thing and essentially answered my own question. I think the exhaust studs should work.
-Taylor
1984 ROW Carrera
Let's go Tech!
Old 02-18-2014, 08:49 AM
