MFI engine does not rev past 6.5K
My mfi engine does not reve past 6500 rpm.
is this because the mfi pump is not pumping enough fuel to achieve higher high rpm(calibratrion problem) or there is not enough spark advance? I use a clewett engineering twin plug ignition module
Old 02-08-2014, 03:34 AM
Home of the Whopper
Most fuel injection problems are ignition, so I would start there. Good luck!
1968 912 coupe
1971 911E Targa rustbucket
1972 914 1.7
1987 924S
Old 02-08-2014, 05:25 AM
E Sully's Avatar
What do the spark plugs look like? Any carbon from running rich, or too white from lean? What is your maximun ignition advance? Less is better with twin plug than single plug.
ignition advanced with twin plug
Ed
1973.5 T
Old 02-08-2014, 06:01 AM
bavaria911's Avatar
Maybe it is as easy as the rev limiter rotor?
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 02-08-2014, 06:54 AM
gptom's Avatar
T engines had a rev limit of 6500. Rotor would cut out. Which engine do you have?
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 02-08-2014, 09:53 AM
pors1968's Avatar
Like Bavaria 911and GPTOM i would try a new rev limiter rotor or check on rotor it written rpm limit.
Old 02-08-2014, 11:45 AM
2,9 short stroke mfi
I built this 2,9 short stroke MFI .
Yes. Probably the rev limiter is the problem.
I can reprogram the Clewett twin plug ignition moduleto limit at 8000 rpm instead of 7000 rpm. Max advance is 20 degrees
Old 02-08-2014, 03:52 PM
It's a 914 ...
stownsen914's Avatar
I think the other posters were speculating that if you still had the distributor, that the rev limiting mechanism in the rotor might be failing you. If you have a Clewett ignition, this shouldn't be an issue though. Can't hurt to check the rev limit on your ignition module though ...
Did you make any changes right before this started happening? If you can think of anything, I'd look there first.
As for diagnosing, do you have an A/F monitor or EGT on your car? If so, it would indicate if you're going rich or lean when the engine starts misfiring.
Scott
Old 02-09-2014, 04:58 AM
I can place the rev limit at 9000 rpm on the Clewett ignition module. It is programmed for 25 degrees advance.
Old 02-09-2014, 09:31 AM
AFR meter
good idea. I have an AFR meter which I have not hooked up yet and I will see where the mixture is
Old 02-09-2014, 09:21 PM
