momo competition wheel/extended hub-anyone using?
I need to get my wheel up and out a bit to give some more leg clearance and less arm stretching, so I was thinking of the Momo competition wheel (http://www.pelicanparts.com/catalog/shopcart/MISC/POR_MISC_mowhel_pg20.htm) and the extended hub (MO-L231 http://www.drivewerks.com/catalog/shopcart/DWKS/POR_DWKS_mohubs_main.htm). Anyone using either of these? With the extended hub can I get by without using the spacer? I'm assuming the 350mm wheel will give me a little more leg clearance by itself relative to the stock SC wheel.
I have the long hub installed, though not with that particular wheel. For leg room (I need all I can get) the long hub is better but I added two spacers as well.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
I'm using that exact wheel with the MO-C231 hub adapter (no extension), and I have well over 1.5" of clearance between the dash and the wheel. Thigh room isn't an issue at all. It's a full 1" or more smaller than the stock wheel so even an extender isn't a necessity.
And the silly logo will scratch off with a fingernail on a hot day, I've found. How convenient!
Mark Szabo 1986 911 Targa 3.2 (I will miss you) 1985 Scirocco 8V (I will not miss you) 1986 Dodge B150 Ram Van (I can't believe I got $200 for you) 1987 Escort 5-speed 1.9 RIP |
