-   -   Need control pressure spec for 77 3.0 carrera row and proper WUR number (http://forums.pelicanparts.com/porsche-911-technical-forum/796027-need-control-pressure-spec-77-3-0-carrera-row-proper-wur-number.html)
kodioneill 02-10-2014 10:47 AM
I have a 77 euro 3.0 carrera What is the correct WUR # and what are the proper warm and cold control pressures? Thanks much.
soren.911 02-10-2014 11:08 AM
WUR 0438.140.017
Cold 1.2 bar warm 3.1 bar
kodioneill 02-10-2014 11:14 AM
the wur that's installed is a 140 033
boyt911sc 02-10-2014 12:11 PM
Wur-033......
Both WUR-017 and WUR-033 should work for your '77 Carrera (Euro) provided the specifications are all correctly set-up. What problems are you having with your fuel pressures? Keep us posted. PM sent.
Tony
kodioneill 02-10-2014 12:38 PM
Thanks Tony. I have a problem with the warm pressure it's 3.8 bar. Spec calls for 2.7-3.0 bar. Cold seems normal @ .5 bar. System pressure @ 5.0 bar.
boyt911sc 02-10-2014 01:55 PM
Wur-033......
kodioneil,
The cold control fuel pressure is too low!!!!! And that's not NORMAL. Your WCP is still within specification but on the high side. You are mis-reading the WCP spec values:
(2.7 - 3.1 bar)........no vacuum
(3.4 - 3.8 bar)........with vacuum
Keep us posted.
Tony
kodioneill 02-10-2014 02:01 PM
What is the cold pressure spec? this is a euro 3.0 car.
Bill Verburg 02-10-2014 02:07 PM
Mike
do you have the spec book?
per mine
control pressure(wur off) at idle, throttle closed 3.6+/-.15bar
engine stopped, fuel pump running 2.9+/.15
system pressure 4.5-5.2bar
you can make it adjustable easily enough, I have instructions if you need them
I used to just tap mine to where I wanted it. You had to disassemble it if you went too far though(a potential PIA)
kodioneill 02-10-2014 02:09 PM
thanks Bill what's the cold spec? Don't have a book for euro spec.
kodioneill 02-10-2014 02:23 PM
http://forums.pelicanparts.com/uploads15/EarlyWURs1248319527.jpg
does this graph for the 033 wur indicate .5 bar@10c and 2.7bar warm?
Bill Verburg 02-10-2014 02:35 PM
This is from the '76-77 spec book
http://forums.pelicanparts.com/uploa...1392071709.jpg
Bob Kontak 02-10-2014 02:41 PM
The graph Bill posted is for cold control pressure. It is a function of ambient temperature so as it gets warmer the cold control pressure increases (leans).
Warm pressure is a range, period. Not on a graph.
kodioneill 02-10-2014 02:43 PM
Thanks Bob
Bob Kontak 02-10-2014 02:48 PM
Originally Posted by kodioneill (Post 7903527)
Thanks Bob
I can pull several threads where I assumed that the CCP graph was for both. It's confusing at first blush but makes sense when you think about it.
boyt911sc 02-10-2014 03:18 PM
Different reference graphs.........
Mike,
There is a discrepancies in our reference graphs. I am using the factory shop manual from Porsche which shows a completely different slope for WUR-033 from yours. I've been using the graphs from my factory shop manual for almost 20 years and never had problem with the setting. So I'm sticking to my reference charts and let you decide which to use. Good luck.
BTW, 0.5 bar cold control pressure setting is too low based from actual tests and my experience working with all sort of Bosch WUR's 0-438-140-xxx. But if you are happy with this setting and it works for you, just keep it that way.
Tony
boyt911sc 02-10-2014 03:28 PM
Cold control fuel pressures.........
This is also true for CCP.
Tony
kodioneill 02-10-2014 05:28 PM
Thanks Tony and Bob. I'll try the high end of the ccp @ 10c.
kepa75 07-12-2024 10:55 PM
Hello,
Has this ever been solved? I mean the discrepancies in our reference graphs for the WUR-033.
In the workshop manual of Porsche it shows a different graph compared to the graph in the Types, Dimensions, Tolerances softback book (always from Porsche) or compared to the graph in some Bosch workshop manuals?
My WUR-033 is set to the TDT (or Bosch documentation) and I'm wondering if I should rebuild it to the graph in the workshop manual?
Thanks,
Peter
Schulisco 07-13-2024 05:18 AM
Originally Posted by kepa75 (Post 12282733)
Hello,
Thanks,
Peter
I suppose that the different WUR pressure specs are not that cruicial in any case for a 911. Of course they should be clarified if there are wrong specs given. I suppose you're asking while you got some issues on your 911. I recommend to start a new thread or search for symptoms similar to your car here in the forum.
Thomas
