kodioneill's Avatar
Need control pressure spec for 77 3.0 carrera row and proper WUR number
I have a 77 euro 3.0 carrera What is the correct WUR # and what are the proper warm and cold control pressures? Thanks much.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-10-2014, 10:47 AM
soren.911's Avatar
WUR 0438.140.017
Cold 1.2 bar warm 3.1 bar
1974 911 cab. RoW 3.2 with carrera3 CIS, Bosch HKZ ignition, SSI, 915- 7:31, curb weight 1115Kg, 231Hp.
BMW 530dA touring
Old 02-10-2014, 11:08 AM
kodioneill's Avatar
the wur that's installed is a 140 033
1982 chiffon 911sc
Old 02-10-2014, 11:14 AM
Wur-033......
Both WUR-017 and WUR-033 should work for your '77 Carrera (Euro) provided the specifications are all correctly set-up. What problems are you having with your fuel pressures? Keep us posted. PM sent.
Tony
Old 02-10-2014, 12:11 PM
kodioneill's Avatar
Thanks Tony. I have a problem with the warm pressure it's 3.8 bar. Spec calls for 2.7-3.0 bar. Cold seems normal @ .5 bar. System pressure @ 5.0 bar.
1982 chiffon 911sc
Old 02-10-2014, 12:38 PM
Wur-033......
kodioneil,
The cold control fuel pressure is too low!!!!! And that's not NORMAL. Your WCP is still within specification but on the high side. You are mis-reading the WCP spec values:
(2.7 - 3.1 bar)........no vacuum
(3.4 - 3.8 bar)........with vacuum
Keep us posted.
Tony
Old 02-10-2014, 01:55 PM
kodioneill's Avatar
What is the cold pressure spec? this is a euro 3.0 car.
1982 chiffon 911sc
Old 02-10-2014, 02:01 PM
Bill Verburg's Avatar
Mike
do you have the spec book?
per mine
control pressure(wur off) at idle, throttle closed 3.6+/-.15bar
engine stopped, fuel pump running 2.9+/.15
system pressure 4.5-5.2bar
you can make it adjustable easily enough, I have instructions if you need them
I used to just tap mine to where I wanted it. You had to disassemble it if you went too far though(a potential PIA)
Bill Verburg
Old 02-10-2014, 02:07 PM
kodioneill's Avatar
thanks Bill what's the cold spec? Don't have a book for euro spec.
1982 chiffon 911sc
Old 02-10-2014, 02:09 PM
kodioneill's Avatar
http://forums.pelicanparts.com/uploads15/EarlyWURs1248319527.jpg
does this graph for the 033 wur indicate .5 bar@10c and 2.7bar warm?
1982 chiffon 911sc
Old 02-10-2014, 02:23 PM
This is from the '76-77 spec book
Bill Verburg
Old 02-10-2014, 02:35 PM
Fleabit peanut monkey
Bob Kontak's Avatar
The graph Bill posted is for cold control pressure. It is a function of ambient temperature so as it gets warmer the cold control pressure increases (leans).
Warm pressure is a range, period. Not on a graph.
1981 911SC Targa
Old 02-10-2014, 02:41 PM
kodioneill's Avatar
Thanks Bob
1982 chiffon 911sc
Old 02-10-2014, 02:43 PM
Bob Kontak's Avatar
Thanks Bob
I can pull several threads where I assumed that the CCP graph was for both. It's confusing at first blush but makes sense when you think about it.
1981 911SC Targa
Old 02-10-2014, 02:48 PM
Different reference graphs.........
Mike,
There is a discrepancies in our reference graphs. I am using the factory shop manual from Porsche which shows a completely different slope for WUR-033 from yours. I've been using the graphs from my factory shop manual for almost 20 years and never had problem with the setting. So I'm sticking to my reference charts and let you decide which to use. Good luck.
BTW, 0.5 bar cold control pressure setting is too low based from actual tests and my experience working with all sort of Bosch WUR's 0-438-140-xxx. But if you are happy with this setting and it works for you, just keep it that way.
Tony
Old 02-10-2014, 03:18 PM
Cold control fuel pressures.........
This is also true for CCP.
Tony
Old 02-10-2014, 03:28 PM
kodioneill's Avatar
Thanks Tony and Bob. I'll try the high end of the ccp @ 10c.
1982 chiffon 911sc
Old 02-10-2014, 05:28 PM
Hello,
Has this ever been solved? I mean the discrepancies in our reference graphs for the WUR-033.
In the workshop manual of Porsche it shows a different graph compared to the graph in the Types, Dimensions, Tolerances softback book (always from Porsche) or compared to the graph in some Bosch workshop manuals?
My WUR-033 is set to the TDT (or Bosch documentation) and I'm wondering if I should rebuild it to the graph in the workshop manual?
Thanks,
Peter
Old 07-12-2024, 10:55 PM
Schulisco's Avatar
Originally Posted by kepa75 View Post
Hello,
Thanks,
Peter
I suppose that the different WUR pressure specs are not that cruicial in any case for a 911. Of course they should be clarified if there are wrong specs given. I suppose you're asking while you got some issues on your 911. I recommend to start a new thread or search for symptoms similar to your car here in the forum.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 07-13-2024, 05:18 AM
