Which original radio models on 911 SC 1982
Can anyone inform me which original radio models were fitted on a 911 SC on 1982?
Brand and models?
I don't know if the one fitted on my car is original, on this project: yes! Forward but diferent!
As it is not working, I would like to fit a new one.
K-Jetronic student
Old 08-30-2012, 03:52 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Peter Morgan's book clusters the SC and 3.2 options together. If it is not a Blaupunkt I don't think it is original.
Blaupunkt (optional listed radios - and I am not sure this is complete)
M326 Berlin
M327 Koln
M328 Bremen
M328 Symphony (duplicate option number)
M329/330 Toronto
M160 Charleston
M158 Monterey/Reno
Old 08-30-2012, 07:27 AM
86FlatSix
JQ911's Avatar
Wow that was helpful!
I was looking for a Monterey SQ23 for my 86 and ended up with a Charleston. Does that mean I am on the right track in bringing it back to the original set-up?
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 08-30-2012, 07:36 AM
Thanks Bob! Very helpful!
K-Jetronic student
Old 08-30-2012, 08:03 AM
Bob Kontak's Avatar
The book states that option M158 was the Monterey in 1986 and the Reno in 1987. Those are the only years provided that are associated with the radio options. However, the Charleston is option M160 and then the option numbers jump into the M300's. Can that mean the M158 and M160 are for the SC's and earlier 3.2's?
It's not clear to me from this single source and if Peter Morgan can't get a clear picture, doubt we can. I do have one or two more books I can look at. Will advise if I find anything.
Edit: Red Books says the same thing.
Have not see where Charleston is not an option for 86/87.
Old 08-30-2012, 08:18 AM
The Monterey was first used in 1983 and was the standard radio through the 86 models. It's a problematic radio to use these days, as the pushbuttons fail and original parts are NLA. There's a "fix" but it's not a great solution.
An '82 used a different radio. I don't recall offhand what the model name was (probably the Bamberg QTS) but the one in your car looks decent. If it works, and you like it, use it.
JR
Old 08-30-2012, 08:24 AM
Bob Kontak's Avatar
JQ911 - See post 7 in link below.
FS Blaupunkt Charleston SQR 26
Old 08-30-2012, 08:30 AM
An '82 used a different radio. I don't recall offhand what the model name was (probably the Bamburg QTS) but the one in your car looks decent. If it works, and you like it, use it.
JR
Yes, i would like to use it... because i suspect it is original on this car... The problem is it doesn't work...
K-Jetronic student
Old 08-30-2012, 08:35 AM
Get it repaired...
JR
Old 08-30-2012, 08:39 AM
Meanwhile, I found this, for those interested on this subject:
Porsche Radios // www.turbosition.com
K-Jetronic student
Old 08-30-2012, 08:42 AM
Get it repaired...
JR
It is a solution, yes... the problem is to get someone interested on doing the job here in the island.
But I will try to contact one guy that probably can help.
K-Jetronic student
Old 08-30-2012, 08:43 AM
You have to be a little careful with some of the posts on this forum, with sites like the second link, and in reading the various Porsche books, PET, etc.
There are a lot of errors.
Also, Porsche made it hard, in that not all markets used the same radios in a given year. And, often a 911 and a turbo of the same year used different radios. Blaupunkt made it hard by re-using most of their names over and over. There are several different versions of the Bamberg, Koln, etc. Nothing similar about each version... And, radios like the Monterey had near clones. They might change one or two details (like the presence of an on-board fader) and call it something else. Or, it would be known as something else in a different market. There is a Bamberg and a Koln that are essentially the same as a Monterey.
To be sure, you have to refer to original factory documentation for the market in question. Sadly, I just gave away and threw away some of this stuff... I do know that in '86, you got a Monterey as standard. I'm 99% sure that a 911 used a Charleston in 1987 and a turbo used a Reno. I think the Reno was an option for the 911 that year.
JR
Old 08-30-2012, 08:56 AM
Thanks Javadog.
Anyone has the access to original factory documentation? That would be a great help!
K-Jetronic student
Old 10-03-2012, 02:28 AM
radio
I think in the US Market most often you saw these radios:
CR2000/CR2001 78-80, CR3001/CR3001H 1981-1982,
blaupunkt monterey 1983-86 and Reno 87-89
Old 12-12-2012, 09:59 PM
I already manage to identify mine: Heidlberg SM 21, among st other options.
I will try to find one of these, otherwise I'll choose one of the other suggestions.
Thank you all.
K-Jetronic student
Old 12-14-2012, 01:19 AM
Boricua21's Avatar
My 82 SC has a Blaupunkt CR3001 (with a shot display). I am almost sure that is the one that was installed at the factory when new.
Arnie Diaz
Braselton, GA
1982 911 SC (3.2), Fabspeed Bypass and Muffler
2003 E39 BMW 530i (Daily Driver)
Old 12-14-2012, 07:41 PM
KKothand's Avatar
Sorry to jump into this thread, but I do need some advise which is related to this topic. I have a 1982 911SC, which has fixed antenna, but NO RADIO. The place where there should be a radio is covered up as if it was never installed. Is it possible for me to install a basic radio? Thanks.
Old 01-12-2014, 05:17 PM
Sure, it is very easy.
I would recomend the installation of an original rádio (check your data at Porsche) - there are several available.
K-Jetronic student
Old 01-13-2014, 03:24 AM
here are the original Radios which were built in Porsche 911 from 1975 to 1989 here in Germany:
Modell 1975
Blaupunkt M-Nummer
- Frankfurt 452
- Lübeck 449
- Köln 421
- Bamberg 422
Modell 1976
Blaupunkt
- Frankfurt 452
- Köln 421
- Bamberg 422
Modell 1977
- Köln 421
- Bamberg 422
Modell 1978
Porsche CR Stereo 351
- Typ USA 389
- Typ restl. Welt 422
Blaupunkt
-Frankfurt 452
Modell 1979
- Typ USA 389
Modell 1980
-Typ restl. Welt 422
Modell 1981
Dig. Radio
Super Arimat 115
Digital Radio 126
Modell 1982
Dig. Radio
Super Arimat 115
Digital Radio 126
Modell 1983 (bis 14.03.83)
Blaupunkt
- Köln SQR 22 327
Modell 1983 ( ab 15.03.83)
- Köln SQR 22 327
- Atlanta SQR 22 330
Modell 1984
- Köln SQR 22 327
Modell 1985
- Köln SQR 23 327
Modell 1986
- Bremen SQR 46 328
- Toronta SQR 24 330
- Hamburg SQM 24 686
- Boston SQM 23 688
Modell 1987
- Berlin IQR 86 326
- Bremen SQR 46 328
- Toronto SQR 46 330
- Ludwigsburg SQM 26 686
- Boston SQM 23 688
Modell 1988
- Berlin IQR 87 326
- Bremen SQR 46 328
- Boston SQM 23 688
Modell 1989
- Berlin IQR 87 326
- Bremen SQR 46 328
Michael
Old 02-11-2014, 11:16 PM
Keep in mind that there were sometimes different names used for the radios fitted to US cars, vs. the similar models in Europe.
JR
Old 02-12-2014, 06:55 AM
