Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Need help with my fuel distributor fittings.
Hi all,
Based on a recommendation from my mechanic (long story) I've swapped out my fuel distributor from the hard line version to the soft line version. The problem is, my old fittings are the press fit kind (I'm sure there's a professional name for them) and my new connections are banjo fittings. I just did a search here and found a couple of ridiculously expensive parts. So...can I source these parts locally from an import parts place, or am I (for lack of better words) hosed?
Michael
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 07-23-2013, 06:44 PM
FD fuel line fitting adaptors........
Originally Posted by emptyo View Post
Hi all,
Michael
Michael,
So you need six (6) 8-mm banjo fittings for the FD? I have an extra set for you if you want swap your old fittings. PM sent for details.
Tony
Old 07-23-2013, 08:29 PM
47silver's Avatar
if i can ask why?
why did you remove your hard lines? I have a 75 with soft and for safety would think that hard are better.
1975 911S Targa
Silver Anniversary Edition
Old 07-23-2013, 09:44 PM
I built my own fuel lines because of a fuel distributor relocation. I needed to free
up some space to install a larger intercooler.
Purchased everything from B.A.T. Inc. in Flordia.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 07-24-2013, 07:29 AM
47silver's Avatar
oh i see
very nice now it makes sense
1975 911S Targa
Old 07-24-2013, 07:31 AM
Rennch on YouTube
rennch's Avatar
So, I have all of the lines attached to the distributor (Looks like Predator. Heh heh...) but I need the connection to the other ends...basically the banjo fittings that go to (is it the WUR?) the bottom, by the injectors on the left side.
Michael O'Neal -
Old 07-24-2013, 07:49 AM
BoxsterGT's Avatar
Porsche Crest
Is this what you are looking for?.......
I have most of the single fittings in stock. The compound ones are what I am trying to find.
Also have started making these.............
....for a fellow in the UK. Got the injector end done, now working on the Banjo fitment and it is tough. Have to make a special assembly tool for this.
Len
Old 07-24-2013, 01:20 PM
Rennch on YouTube
rennch's Avatar
Hi Len...I have the hose. I need the fittings that go into the banjo side.
Old 07-24-2013, 01:29 PM
Rennch on YouTube
rennch's Avatar
I'll take pics today.
BoxsterGT's Avatar
Porsche Crest
I have the Banjos in stock. Please email me for details. Cannot send photos via PM.
Len
Old 07-24-2013, 01:51 PM
Rennch on YouTube
rennch's Avatar
Great, thanks Len.
Michael O'Neal -
Old 07-25-2013, 10:10 AM
BoxsterGT's Avatar
Porsche Crest
Its been a while, but I am having fittings for the FD w seal rings and Male Cone ends made by a local machine shop. These are designed to accept Polyamid or SS lines with Female nipples at each end.
They are similar to the fitting shown below.
When I searched for these a while back I could not find them anywhere. These are M10 Seal Ring x M12 Male cone and it looks like PN 900 915 004 02. Perhaps someone can verify this.
Len
Old 02-09-2014, 10:03 AM
If you have access to a local wrecking yard (i.e., pick a part), you might pay a visit and pull fittings from Mercedes and VW. I recently was at my local wrecking yard and pulled all those little hollow banjo bolts to complete a spare fuel distributor. They are not all an exact match but many are (including the bolts that fit into the top of the FD and the larger banjo bolt that fits into the WUR and the fitting that fits into the center of the FD (output to the wur). The fittings that are not the same were double threaded piece that fits into the wur.
Old 02-09-2014, 01:04 PM
CharlieB's Avatar
Fuel distributor fittings
Len: Tried to send you a PM but you've "exceeded your storage capacity". I need seven of the above FD fittings for a soft line to hard line conversion on an 80SC. Charlie
Old 02-12-2014, 07:47 AM
BoxsterGT's Avatar
Porsche Crest
Hi Charlie-
If you mean the ones above in post #12, it looks like I messed up, as the ones above do NOT fit the Fuel Distributor.
I have a number of fittings being made, and I just assumed these were for the FD. The lower half to accept a seal ring is too large.
How embarrasing.
Once they are back from the platers I will have to figure out where they go.
Please email me for all inquiries. I cannot track messages or send photos via PM.
All you have to do is go to my user name and pick "send email".
Thanks,
Len
Old 02-12-2014, 03:33 PM
CharlieB's Avatar
Emptyo: You have a PM from Charlie
Old 02-13-2014, 04:27 PM
FD fittings for metal fuel lines........
Originally Posted by BoxsterGT View Post
Hi Charlie-
How embarrasing.
Thanks,
Len
Len,
The fitting size for the FD is 8 mm x 1.0 for both sides (distributor and fuel line). HTH.
Tony
Old 02-13-2014, 06:29 PM
Almost Banned Once
sc_rufctr's Avatar
This is brilliant!
Cole
- Peter
Old 02-13-2014, 06:42 PM
