fred cook's Avatar
air/fuel ratio question...........
I have been tuning the fuel injection on my 3.3SS engine using an a/f ratio gauge. At the moment, I have it adjusted to run right at stoichiometric (14.7:1) during "normal" driving. At full throttle, it will go to about 13.5:1. While I know that this is close to "ideal", is it too lean for day to day driving? The engine starts easily and once warm holds a nice steady idle at 950 rpms. The fuel injection system that I am using on this engine is a modified CIS system made from a large port air box and later (1980) fuel distributor and throttle body. The miscellaneous controls have been backdated to be similar to a 1973 1/2 type system.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 02-16-2014, 09:50 AM
Vereeken's Avatar
At full throttle 13.5 is too lean.
It will not do any harm but you are leaving some horses behind. 12.9 13.1 would be perfect for our engines....
My 2 cents.
Michel
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses.
Old 02-16-2014, 10:01 AM
ROW '78 911 Targa
timmy2's Avatar
I set mine to 12.5 at full throttle on my AFR map. Pulls great at WOT.
The 14.7 for cruising should be fine, I keep mine around 14.5.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-16-2014, 11:59 AM
fred cook's Avatar
Minor adjustment
My 2 cents.
Michel
Not a problem, most likely about 1/8th of a turn on the adjustment screw. Since I am working with the basic CIS system, top end enrichment is related to the cruise a/f ratio. I do have a switch installed that activates the cold start valve at full throttle. It acts as a 7th injector to help keep from going lean. The cold start valve manifold makes certain that each cylinder gets some of the extra fuel. I know that the conventional wisdom would be to use PMO carbs or ITBs, but I wanted to see what I could get out of the CIS, keeping the easy start and reasonable fuel mileage that it provides.
FEC3
Old 02-16-2014, 02:27 PM
ROW '78 911 Targa
timmy2's Avatar
What are you running at idle when fully warm?
Should be around 13.8 to 14.
Dennis
Old 02-16-2014, 03:32 PM
