-   -   A/C to keep or delete (http://forums.pelicanparts.com/porsche-911-technical-forum/796917-c-keep-delete.html)
wwest 02-18-2014 08:46 AM
Originally Posted by LenS (Post 7917521)
+1
And removal makes working in the engine bay so much easier.
Let's see now, when was the last time I had to work on my engine......
mysocal911 02-18-2014 10:15 AM
Originally Posted by Nick Triesch (Post 7914846)
I think you should fix it and keep it! If it is a real hot day and you have Porsche A/C, then when you turn it on the car will go from 97 degrees down to 89 degrees in nothing flat!!
Agreed, I like to keep my Porsche totally stock.
zaman fu 02-18-2014 10:37 AM
I say remove it if you don't need it. Just keep the parts in case you sell one day, and the prospective buyer is a stickler for originality. I don't get this obsession with "totally stock," especially with things that were added to comply with government regulations but which dilute the purity of the car (sugar scoop headlights, third brake lights, emissions components, etc.).
daleflesburg 02-18-2014 10:50 AM
My car is my car. I am 72 and the car was built in 74. It will go to my son in 20 years or whenever!
It is what I wanted. It has headers (no heat) and all heat related parts are gone. It never had air. It has no sunroof. It has no electric windows (gives my left arm some exercise). It has no radio, (since you cannot hear it anyway). It has no fresh air controls (did not work anyway). It has a 3.2 L engine. It weighs 2360#s. It is a blast to drive.
If it is below 50 or above 100 though, I drive my Boxster. It is fun too, but in a very different way.
wwest 02-18-2014 11:03 AM
Yes, if there is really no opportunity for "sport" driving then I choose my '95 LS400, except for foul weather in which case the '01 (AWD) RX300 comes out.
But many are "stuck" with a single "sport" vehicle and there is no good reason for those to suffer daily with no heat or no cooling.
daleflesburg 02-18-2014 11:12 AM
I am not arguing with anybody about what they should do, but just one comment. I never met an air cooled 911 (1989 or older) that had AC anywhere near adequate to keep up in weather hotter that about 85 degrees. My Dad's 66 Chevy had better air than any air cooled 911 I was ever around.
Tilikum Turbo 02-18-2014 11:19 AM
First try this...
One, make sure your Freon is full charged.
Two...for about 5 dollars, go to Home Depot, and buy a 10-foot length of at least 1-inch thick foam insulation for pipes. It's usually charcoal grey, flexible, and can be easily cut.
Take a look at your AC system under the hood for starters...there are HOT and COLD lines...you want to insulate the COLD lines, as they need to be kept as cold as possible. The heat transfer from the engine to those cold lines really drops the ability to make the system work well, and since the system travels the entire length of the car, this really strains it.
Also, make sure the HOT lines are as clean as possible, to transfer the heat OFF of them. The further the spread in temp from hot lines compared the cold lines, the better the system will cool. Good luck.
GH85Carrera 02-18-2014 12:01 PM
You have never seen a Griffiths Dual condenser system car. My 911 kept us comfortable in Savannah GA in August. I drive it in 100+ degree days all the time. It does great.
The subject comes up all the time. It all comes down to what you want to do with your own car. If you don't mind a car that can only be driven on nice days fine. I prefer my car that will take me to California right through Death Valley to spend a week in Monterrey this June. I can go through mountain passes and stay warm and I can drive in central California in 110 degree heat and stay comfortable.
It is your car. Do whatever you want.
wwest 02-18-2014 12:04 PM
But
That WAS exactly my experience with both my '78 Targa and the '88 Carrera. But it is my most humble opinion that the major shortcoming is the lack of condenser heat transfer capability in other than highway cruise conditions.
The first thing I experimented with was adding additional cooling capability to the rear lid condensor whenever the compressor clutch is engaged. That most definitely solved the problem of inadequate A/C cooling capability for me here in the PNW.
Then the issue of loss refrigerant consistently, ~2 year cycle, brought me to pay attention to that issue. So in analysis I came to believe that the loss of refrigerant had a direct relationship to system pressures, specifically EXTREME system pressures.
So the system in my '88 has now been revised to include a trinary pressure switch both to protect (***1) and control (***2) the compressor clutch, while the third switch element is wired to pin 10 of the cabin heat controller.
Jury is still out as to whether or not this will prevent the loss of refrigerant, R-134a specifically.
***1 Prevents the compressor from operating with not enough refrigerant in the system.
***2 Prevents the compressor from over pressurizing the system above ~454 PSI
Nostalgic AC - Male Trinary Safety Switch For Electric Fans - AC Pressure Switch - Oil & Switches
The above link is to the trinary pressure switch currently installed in the '88. 454 PSI high limit seems a bit much for our legacy systems as many of these components were not guaranteed against leakage above 35 bar, 500 PSI, with BURST pressures in the 50 bar, 800 PSI range.
So I have a RED DOT trinary switch, 325 PSI high pressure compressor limit, which I will install before spring.
Trinary II™ Switch Freightliner OEM# RD 5-4585-0
krasuskyp 02-18-2014 12:07 PM
was the first thing I scrapped, stem to stern - but I don't live in the south
it didn't work, and if/when that system does it's mediocre at best
and it weights a kajillion lbs - with most of that kajillion lbs dangling wayway out beyond the rear axle
and it obstructs just about any / every service
and it requires to be 'slung' over the fender for just about any / every service not just removed
and I got good $$$ for the system
and I sold the car pretty quickly / easily for good money years ago - and the subject of a/c or "original parts" for that matter (long ago sold off in entirety) never was once part of any convo on the sale subject and had zero affect on value (I've since repurchased it heh heh). Hmmmm.
Windows down, sunroof open - drive faster. My pretend world / happy place does have me fantasizing about rear 3/4 window retrofits, I'll admit. That would make alllllllll the difference. Sigh.
If it's too damn hot, I'll skip that day. But as was said, it's 4th car so...
my useless perspective...:D
Nico911 02-18-2014 12:07 PM
Originally Posted by boss11 (Post 7914478)
removing a/c was one of the first things i did to mine, haven't looked back
it is a targa though
+1
