Can MFI injectors be cleaned?
Can MFI Bosch in injectors be cleaned? They don't seem to come apart. Can I send them to witch hunter to be cleaned?
I don't believe that witchhunter will work on MFI injectors. While restoring my 71E, quite a few years back, I purchased an MFI diesel injector tester from a company up in Bellingham Wa. that specializes in Mercedes parts. The Porsche MFI injectors worked with the tester fittings perfectly. I swapped out the pressure gauge for one that matched the Porsche injector pressures, filled the tester with solvent and basically cleaned the injectors while testing them. Worked great.
https://mercedessource.com/store/diesel-fuel-injector-balance-pressure-tester-yes-you-can-do-it-yourself |
| All times are GMT -8. The time now is 03:19 AM. |
