Can MFI injectors be cleaned?
Can MFI Bosch in injectors be cleaned? They don't seem to come apart. Can I send them to witch hunter to be cleaned?
I don't believe that witchhunter will work on MFI injectors. While restoring my 71E, quite a few years back, I purchased an MFI diesel injector tester from a company up in Bellingham Wa. that specializes in Mercedes parts. The Porsche MFI injectors worked with the tester fittings perfectly. I swapped out the pressure gauge for one that matched the Porsche injector pressures, filled the tester with solvent and basically cleaned the injectors while testing them. Worked great.
https://mercedessource.com/store/diesel-fuel-injector-balance-pressure-tester-yes-you-can-do-it-yourself
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
