3,1 engine weber 40
I have a 3,1 engine project:
70.4 crank
97 mm JE 9.5 cr pistons
3,2 heads
twin plug vs single plug
S cam vs dc 80cam
I would like to know if I can use weber 40carbs for this engine. hopefully it is not too small for the engine.
Old 02-17-2014, 03:40 PM
Under the radar
Trackrash's Avatar
IMO it will depend on your intended use. For a street or AX motor you will be better off with the 40s. However, depending on your cam choice and exhaust you could possibly gain some HP with the 46s.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-17-2014, 04:03 PM
You need 46's for that application.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-17-2014, 04:05 PM
